Also worth noting was the subframes I used were the original ones - the rear is identical, just used the mounts from the engine.
The front I was all set to use the old subframe from the coupe, as it has cut outs etc for various parts - but I hit a snag that the vario's chassis leg mounts were about 1" narrower and 2" further forward than the coupe's (it's not a bent car...)
So I used the Vario's one - and it mounts just fine. (so same as 1.4 etc)
