paradyne
134
43
UK, Bucks
Hi guys, I picked up a silver 2002 Cupra 20VT recently - body in decent shape though it has some rust corrosion around the front jacking points/pinch welds
N/S slightly distorted but rusting in places. O/S is pretty flattened, literally took off the jacking point cover and you cannot see the seam.
Anyone here had to straighten theirs out or address corrosion in that place?
Reactions: Jay20VT
This is like mine.. the jack points are pretty managled after being jacked up incorrectly. I straightened mine with a bolster and hammer which was quite harsh, you can use vice grips too. I then cleaned it and covered the area with Hammerite to stop rust.
Taking the skirts off is quite easy and loads of crap in there which I cleaned up and put back.
Reactions: Mr Pig
Many thanks Jay20VT, I watched a YT vid where someone attacked it in a similar fashion with a punch and grips.
Reassuring hear you've done similar. I've got both available so may well try that approach.
Have already got a tin of the hammerite underseal, just gotta pick a suitable rust converter ahead of painting. My concern would be how much corrosion has gotten into that seam assuming it's possible.
Reactions: Jay20VT
