Apexi Air Intake & SuperPro Bush + the rest
Friday the car was at AmD Essex for cambelt, metal waterpump and full
service. Also during the server I took the opportunity to put on some upgrades. I have heard a lot about these new Super Pro Bushes. From what I have been told by basically everyone at AmD is they are a very good company, very organised and listen to all feedback. They use a slightly difference grade of poly for their bushes and they fit much better than other brands they have used.
SuperPro Dogbone Mount Kit
On that information I decided to opt for SuperPro Dogbone Mount kit. I noted that the kit actually came with an additional bush that goes on the end of the mount. Also the shape of the bushes matched the OE style perfectly, my existing powerflex ones did not.
They come in 3 variants. Petrol, Diesel and Race. Each are a different grade of poly with the Diesel one being specifically made to get the performance of the strong poly bush but without the vibrations associated with rival brands.
Results
They are really really good!! I noticed instantly that the constant vibration/buzz on idle had died down a lot, it just felt like a different car. When driving it was a joy as the harshness of the engine just wasn't there no more. I was also pleased that performance of the mounts was still the same. All in all these are a dream come true for us Diesel owners. Not sure what the petrol variant is like but I am sure they will be just as good.
SuperPro Steering Rack Bush
I heard that the steering rack bush makes steering a more reactive. Comparing the OEM bush and the SuperPro one the SuperPro one was a lot more solid.
Results
The steering a tad lighter. When i took the car for some spirited driving I didn't really notice much difference between the standard one. I only really noticed it when driving slowly just felt a tad lighter and easier to turn where you wanted.
Apexi Power Intake
Apexi Power Intake went on no problems thanks to all the info Adam gave me earlier. AmD did have to give me a mount as the one I got from B&Q as crap.
Results
Well you can certainly hear it sucking in air when the car is idling which is reassuring that it is working. As I had a new MAF installed at the same time I cannot tell whether I have gained any horses or not. When i drove it today with Slick in passenger seat (first day of adaptation) we both noted that the delivery of the power is much much much smoother than it has ever been before. This is either the intake or the MAF but further up the rev range it seems to hold the power a little more consistently.
The sound of the intake is just awesome. People certainly know I am coming down the road with the loud whistle of the turbo and the induction noise that follows. The downside is that all my turbo flutter and air going back up the tip on gear change has gone/cant be heard. This isn't really a negative as but hey it was nice when i had it. Overall I am glad I haven't lost any performance and that its running very well.
Service, Cambelt and MOT
AmD Luke noticed that the top mounts had some play in them. I was shocked as they were replaced 6 months ago when the KW V3s were installed. After a constuctive conversation with Shaun we both agreed that an uprated solution would be best considering all the modifications I have done in the past.
034 Motorsport TRACKDENSITY Strut Top Mounts have been ordered.
TRACKDENSITY Mounts are also solid rubber mounts, but with an 80 durometer approx 90% stiffer than stock, these are solid for all practical purposes and result in very good upper strut location with little slop or movement. Perfect for aggressive street use or track/rally use.
Car is booked in next week to get these installed. Hopefully my VF Drop Links will arrive too!
Service and cambelt went very smoothly, has made the engine run a tad quieter. I got an opportunity to look underneath the car at the H&S pipework. Pretty please with their work
AmD Luke said this was the most highly maintain diesel he ever worked on which made my day. Big thanks to everyone at AmD as usual for top quality work. Got to see the BTCC car being built throughout the day, amazing bit of kit.
