kevlea77
Hi. My family and me have had quite a few VAG motors over the years (A6, passat, Octavia, 3x T25, splitscreen, Jetta, Mk1 clipper, 2x Mk2 and a 2x mk3) and my mum has recently bought an Ibiza 1.2 3cyl 2004. Great little car in bright yellow! Unfortunately its developed a problem.
Mum went to start it one morn and it was turning over but not firing. I went to have a look and my first instinct was that it was the starter motor slipping due to the sound it was making. I tried bumping it down the road but it didn't want to know. Not sure about these 3 cylinder engines as they do sound very different.
I've since bought the Vagcom lead from ebay and have downloaded a program from Rosstech. The EML has apparently flashed on a few times but very intermittent. I noticed once and this was when engine was cold and weather was very cold also.
Here are the results of my scan.
Hopefully somebody on here will be able to see if any of these components are likely to stop the car starting or whether its something more serious. I started to wonder if chain had jumped and put timing out?
VCDS-Lite Version: Release 1.2
Friday, 31 May 2013, 19:55:02.
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56
Address 01: Engine Labels: Redir Fail!
Controller: 03E 906 033 P
Component: 1.2l/4V SIMOS3 00HS4729
Coding: 00071
Shop #: WSC 06402
VCID: 2D2D8AB7F409
VSSZZZ6LZ4R164785 SEZ7Z0D2414062
3 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16804 - Shareware Version. To Decode all DTCs
P0420 - 35-00 - Please Register/Activate
16725 - Shareware Version. To Decode all DTCs
P0341 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 G
Component: ABS 5.7 FRONT V40
Coding: 00044
Shop #: WSC 06403
VCID: 41F5C6075891
1 Fault Found:
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
Please can you help?
Kev
Coding: 00071
Shop #: WSC 06402
VCID: 2D2D8AB7F409
3 Faults Found:
Coding: 00044
Shop #: WSC 06403
VCID: 41F5C6075891
1 Fault Found:
Kev
