Pretty much! Like I say, they're pretty reasonable anyway, but I'm there all the time, so if they know you've been recomended, it'll make it a bit easier.
Let me know if you're stuck for a plan, there's been loads of advice on here already, and I don't want to advertise all over the place on here. Not my garage (I work in IT for E.ON!), nothing to do with me, they're just good, but being that I've a low post count, don't want it to look like I'm advertising!!! Just let me now if you're stuck.
Cool! Cheers again for your help!
Yes it is normal for turbo engines to drink a little oil, my clio used to use a bit and that was a 55plate at 24k and non turbo. Best hose to take off is the lower intercooler hose as thats where the oil will gather, also check the charge pipe. As said mate, if its had a diagnostic check and no problems, no lights, coolant fine, running ok and not using excess oil its fine, has the cambelt been done? More than likely the garage is trying to get money out of you. id check if mine has a bit of blue smoke but i cant as its in 10000000 pieces.
The charge pipe as in the metal one that runs to the turbo its self? l've got someone coming round to do a VAGCOM on it Monday, but l've not had any engine lights come on what so ever! The cambelt was done during the 60k service and its just ticked over 94k now, so l can't see that causing any issues.
Fair comment about the garage just trying to get cash off me, but they didn't even try and quote me for looking at it, just simply put it as an advisory with the MOT papers.
