Pablo23
Hi
This morning I discovered that by bettery was knackered and so I took my 2000 1.6 leon into Kwik Fit this afternoon (After a jump start) to get a replacement. They've replaced it and it starts fine now, the prblem is that now the ABS light stays on and the red brake light flashes and there are 3 (i think) audible beeps when the ignition is turned on now. The guy at the garage checked on the computer and said that the ABS voltage was low! He tried resetting loads of stuff but in the end said that I should take it for a drive and bring it back tomorrow if not fixed itself! I clearly felt I was being fobbed off but needed to get back to work ... any ideas what the issue could be?
Thanks for any help!
I've had a look at the fuses on top of the battery and they all look ok...
