springy996
Hi, I still drive with upcaps on which for an ibiza ain't that good looking. I recently saw some alloys including the tyres. The alloys are OZ Racing Hydra's, they are 16inch and the tyres dimensions are 195/45 r16.
The size of the studs are 5-100, is this correct for a 5 stud ibiza model.
The rim width is 7.5j and offset is 35.
With all of this info, can someone please tell me if this is compatible and if it would fit on my ibiza? I would be very grateful for your help.
P.s: Sorry about the speling, from Belgium :D
They would fit 100%! So go for it!:clap:
Or if u can, try and find some 17"-s... They aren't much more expensive, but fit a lot better on the car![B)]
And keep in mind that a 195 tyre is going to be a bit streched on a 7,5" rim..
Perfect thanks a lot, but what do you mean when you say that 7.5j would be a bit streched.
For the 17inch I'm still hesitating, they look fantastic but i drive a lot in Brussels in the center, scared of scratching them and also the ride confort isnt that great. But Thanks again for you quick reply
No problem mate!
Believe me that the roads that you have there aren't as half as bad as we have here in Croatia![:@]
I was also running on 16", and didn’t want to go to 17" - was worried about the less comfortable (or more uncomfortable) ride! But when i finally went to 17", believe me I didn't notice any difference in comfort!
I mean that the 195 tire will be a little stretched on that width. I have an 205 tire, and 7,5" width and it's a little stretched. So you'll have to look out for bumps more so you don't scratch the wheel...
But you'll get used to it!:)
Here's a picture of mine, to show you what I mean...
Notice a scratch on the front rim...:whistle:
Btw. I'm advising you to look for 17" so you don't make the same mistake I did - buying 16" wheels and tires and then later having to sell them and go for 17".! ;)
Thanks a lot for your relpy mate, you were a great help !!!
I finally bought the 16inch, and if after a while i want 17's I'll buy some and fit them on, they do have a much more agressive look.
And for your alloys nice choice, they most definetely look good and the ibiza
Here's a thread about my car with a few pictures if you'd like to see... http://www.seatcupra.net/forums/showthread.php?t=111538
Seand a few pics of yours when you put the wheels on!:clap:
