PLS HELP! It won't unlock or start
Saybadger
Hi,
I bought an 02 Leon Cupra on Saturday. Drove it around without problems Sat & Sun, but when I went to start it tonight it just turned over really slowly - I mean really slowly and wasn't close to starting.
I then noticed the passenger door had not unlocked. I clicked the remote key a couple of times and the back passenger side door also stopped unlocking and locking. I tried both keys in both the driver side lock (there is no keyhole on the passenger side as you'll know) and in the ignition.
The battery is fine as the windows, air con etc work fine, it just turns over rediculously slowly and won't unlock on the passenger side, even when using the button on the driver's door.
Please help - my girlfriend is going crazy as she needs the car in the morning and the dealer is two hours away (and shut).
I am so disappointed - the car runs so well and I was so pleased to have my first Cupra on Sunday night. I am absolutely gutted.
Saybadger.
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
what if you connect it to some jump leads?
might be enough juice to operate ancilaries, but not enough for the starter
Saybadger
Yes, I thought of that too but haven't tried as have no other car tonight ot run it off. Prob worth a try. Do you think this would also account for the lack of action on the passenger lock though? I wouldn't hink that would take much juice.
mrcoyote
See no evil...
Jul 26, 2004
2,624
Does it work if you pull the handle from inside? If I remember correctly you had to pull it twice to open it as the first time would only unlock the door.
Saybadger
When you pull the handle from the inside on the front door it pushes the button up but when released it drops back down again.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Sounds like a duff battery.
If the battery is fully charged, then I'd suspect the earth straps. The battery is earthed to the bodyshell, try this one first.
The starter motor is earthed to the engine block and between engine and body there is at least one heavy-duty earth connection, usually a braided metallic strap. If this is damaged or working loose it will affect how much power the starter can get.
nick radwell
not that new
Nov 12, 2004
245
aylesbury
or could be at worst a part siezed or sticky starter only way to check too is to have it off a see if it turns freely as it could be cooking itself!
Saybadger
yeah, battery was knackered in the end. Cheers for the support though. You know how it is.
What about this one then..... the wing mirrors switch back for parking - mine have stopped working. I don't actually care that much but it's annoying to have something that doesn't work. Any ideas or are they just busted? The actual mirror adjustment still works - no worries.
