ive got everything and im halfway through it! got wilwood brakes, 310mm discs!
got maf, manifold, samco tip, all the lines, injectors on there way, dp, xxl dynatwist, battery re-location! its alot of work but should be good! currently removing subframe to get the DP in, its pretty big!
it is alot of work but depend how dedicated you are, all i no is i wouldnt want to pay someone to do it!
h17och - are ther different sizes or green dynatwist then? is the one i bought of you an XL? is that ok for the K03s yeah? :D :)
And what would I be able to get out of a K03s?
Can you also tell me what to look for when looking at buying a cupra?
A Dutch guy tested his k03s a few weeks ago on the bank and
253hp (flywheel) and 382nm (282 lb/ft) with jabba and force FMIC
was the result
nick...that airfilter is fine for your k03s mate! with the xxl you need to put the battery in the boot and you wont gain anything with it on a k03s
HoocH
