The key is the outside temperature . The lower the air temperature is, the less water vapour the air can carry ( the dew point ). Thus on a cold day just rain from your overcoat drying in the car after a rain shower will be enough to steam the windows . You can clear it quite quickly by turning up the heater to 29 degrees for 5 minutes and then putting the air con on at 19 c for 5 miniutes , and repeat as required .
This works because the warm air will hold lots of the moisture at 29c ......... this is then condensed out on the aircon plate cooler at 19c and removed from the car via the aircon drain tube .
