Have done a little research and found out the r32 clutch has the same dimensions and fitting as the stock six speed clutch. The 1.8t flywheel has to be used as the r32 flywheel has too many bolt holes.
The only issue is the diaphram springs are different and think they might have to be used with the r32 slave cylinder.
So does anyone know if the r32 and six speed slave cylinder can be swapped?
