kylestyle09
149
Morning All
Disconnected the Battery yeserday, and the radio asked for a code. I put the code fromt eh radio handbook in, but it didnt work? I treid switching it off and on, and then it just said "SAFE", so I turned the radio on, left it 1 hour, and it came up with 2000. I then put the code SEAT gave me, and held the program button, yet it DIDNT DO IT? It locked itself again... have a 2 hour journey at 1pm, and I can't stand it without the radio.
Thanks!!!!
sheffboy
avoiding potholes
May 25, 2007
655
Make sure you aren't entering the code using the number keys.
iirc you use the channel seek < & > to sellect the numbers and press set each time and it moves onto the next.
If you get it wrong you have to wait 30 mins till you can try again.
kylestyle09
149
mate, ive been using the numbers... if using the seek helps your a star and 5 pound is on its way to you lol... i will let you know next time it lets me do it
sheffboy
avoiding potholes
May 25, 2007
655
Dont be daft mate. Information to fellow seat drivers is free on here mate ;)
Just hope you get it sorted.
sheffboy
avoiding potholes
May 25, 2007
655
Just remembered mate. It's not the seek buttons you use it's these. see below
Switch the radio on, The display will briefly read "SAFE" followed by "1000"
Introduce your code by pressing number keys 1-4
eg, if the code was 1734 you would not press the number 1 button as this is already showing "1" in "1000" press number 2 button seven times, number 3 button 3 times and number 4 button four times.
Hope that makes sense
Confirm the code number by preessing and holding the "PROG" key until it beeps and the display reads "safe"
Hope that helps
kylestyle09
149
When it asks for the code, the code displayed starts as 2000, its not 1000 for some raeson. So I do what you just said, and hold the prog key, but it just brings up a number 1 next to safe.. If I enter it again it brins up a 2, then stays "safe", then I cant do anyhting
Its annoying me, and I dont think it can get sorted?
sheffboy
avoiding potholes
May 25, 2007
655
You only get a short window of time to do it or it goes back to 2000 which is sooo anoying.
It's been a while since i've had to do mine but i remeber disconnecting the battery, re-connecting then being sat in the car eagle eyed waiting for the 2000 to change to 1000. you only get a few minutes until it goeas back to 2000....arghhhh!
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
You need to take out the keys from the ignition, press the button to turn the radio on, leave it on, lock the car go do something for an hour, then ebter the code and press scan.
kylestyle09
149
Right, put the code in, got the correct one on screen now, I hold the PTY button and nothing happens? I dont want to press anything else because ill have to wait another hour. HELP PLEASE!!!!!
warren_cox
Back from the dead
According to this picture the button numbers '1 & 3' are the scan buttons
but then this one is different again on the CD unit,
Do you have a pic?
