https://www.ebay.co.uk/itm/VW-Golf-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
this is what i bought and original seat switch.
Does anyone know the difference between
5Q0955547A And 5Q0955547B???
I have looked at a friends car and they have auto lights and wipers as standard and their sensor ends in B however the one I’ve bought aftermarket was ending in A. I think this could be the reason mine is being temperament??
Any assistance would be appreciated
I got this same switch from the same seller. They have been helpful however as it’s a different code to what I have replaced also it’s an upgrade I haven’t had any further advise.https://www.ebay.co.uk/itm/VW-Golf-Passat-Polo-Tiguan-Touran-Sharan-Seat-Leon-Skoda-Rain-Sensor-5Q0955547A/113044902561?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
B is just an updated A, either should work
I used carista to turn on home light things and just coming home work fine. Both visible on car menu settings.
I believe welcome light work just in dark and mine dont work too.I can set the time 10,20,30 seconds etc for the welcome/going home lights. My concern is that the welcome lights don’t come on all the time ? Unless it’s pitch black they don’t come on ? I have them on high sensitivity but at dusk it doesn’t do anything? I think it’s to do with the vcds coding??
me (hopefully)...Hello, maybe you canme (hopefully)...
I got the same error like Jim45 reported in topic https://forums.seatcupra.net/index....sor-coding-mk3-fr.421370/page-14#post-4792159 for my Seat Leon 1.4 FR Facelift (2018)
Sensor für Luftgüte:
1 Fehler gefunden:
262406 - Datenbus fehlende Botschaft
U1121 00 [009] - -
[SoSe_01 - Datenbus fehlende Botschaft]
bestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 4
Kilometerstand: 17403 km
Datum: 2018.12.01
Zeit: 18:27:51
I work with VCDS, but this should not be the problem.
Do you solved this error?
Did you need more information’s?
At the moment I have installed the sensor number 5Q0 955 547 B.
Also I have the sensor number 81A 955 555 A, but here is the same problem.
My original air quality sensor has the number 81A 907 658.
Sorry for my English
Hello Norbert, the error "940292 sensor for sunlight" you get away by doing the following coding:
This sensor is now installed in the light/rain sensor, but the actual function should already work.
- Control unit 09
- IDE08786-ENG124476-Assist Light Functions-Sun Sensor, installed change 2 not installed (translated from de to en)
Yes thats worked thank you.Hello Norbert, the error "940292 sensor for sunlight" you get away by doing the following coding:
- Control unit 09
1 Fehler gefunden:
U1121 00 [009] - -
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 4
Datum: 2018.12.01
Zeit: 18:27:51
Hi, here a VCDS coding instructions, but in German.
But should not be a problem or?
Or see this post...
You also have to code the sub-controller RLS according to your car.
I think for the Seat Leon it is: 00885D
The pre-facelift model and the facelift model differ in the coding.
Mine was same but after factory reset started working.Weird. Just seems to have started workingmust have reset something without realising.
Now I just need to adjust the light sensitivity as the headlamps are on all the time unless it's bright sunlight
