waitsey
Seat Leon Mk2 2.0
Oct 28, 2008
94
Has anyone come across this problem with there 07 Cupra?
The drivers side window has started to rattle and vibrate alot and its really loud and is getting louder. If i crack the window alittle bit-it stops. The seals all look good around the window.
Any ideas on how to fix it? Or should i just take it to a garage?
Many Thanks
Waitsey
I have had a rattle on my drivers side window, I posted up pics of what I did to fix it so maybe do a search but in short there is a metal finger with a rubber pad that rests against the glass. constant slamming of the door makes the glass push against the pad and bends it a little so that it doesn't do it's job.
If you shine a torch down the slot where the glass goes you can see it and reach down there with a long thin screwdriver and bend it slightly.
