Ok, so I fitted this strut brace last night (not my picture) :
All went reasonably smoothly - but not sure on a few things:
1. Do I tighten up the brace so that is pulls the turrets together a bit, or push them apart? And how tight does it have to be?
2. How on earth is it a 'quick release' system - withouth loosing all your settings that you had previously. As far as I can see you have to undo everything to remove it??
3. Should it be making craking noises when going round tight corners? - suppose this show that it works as it is working against the movement of the chassis...?
Thanks,
John
It does look good thoguh
Thanks,
John
