rear washer jet
mjt
365
have you checked to see whether it's blocked?
when i got mine, it was completely blocked with something that looked like limescale. it wouldn't shift, so i just got a new one which wasn't that expensive from a dealer..
can you hear the pump, or is there just no noise when you try?
Nov 27, 2006
1,204
www.cardomain.com
Can you hear the motor whirring ? (might need to be stationary with the engine off to hear this)
If yes, it's probably the hose connection in the tailgate *stop testing at this point, or you'll flood the tailgate
If no, check the fuses.... and then other electrical sources
Could also be a blockage in the nozzle which a pin might help to dislodge ;)
noodle
80
southampton
yeah the motors fine but have just noticed a slight damp patch below the 12v power outlet so am going to have to take some of the boot apart
GRD
167
Sheffield
It is probably the brass pipe that connects the fluid feed to the nozzle which runs through the centre of the motor spindle. Common weakness - it corrodes then snaps. :shrug:
If your nozzle moves with the wiper arm it's f**ked :cry:
VAG parts sell a repair kit for it.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Mine was just a plastic join, i just plugged it back in and that was that, on a related note my squirty nozzle is'nt going around with the wiper, any idea what might be causing that.
MrJohnnyB
358
Sudbury, Suffolk
The squirty jet is just an extension of the arm, ie when the motor turns the arm the jet should move with it. try taking the arm off and having a look at it, perhaps a nutt needs tightening, although would have thought this would cause the opposite ie the arm wouldnt move but the washer jet may..
MrJohnnyB
358
Sudbury, Suffolk
I'll have a look at my arm 2moz when its light to see if i can shed any light on what could be the possible cause, because i just assume its the washer jet slipping some how.
crazyshad1
113
I have a slightly different problem. I seem to be missing the jet, it fires straight into the wiper arm cap. Can a new jet be bough and fitted?
GRD
167
Sheffield
The jet nozzle should not move with the arm - it should squirt vertically onto the rear screen.
That is why there is a slot in the wiper nut cap!
If the jet moves with the wiper arm you have got problems :cry:
mjt
365
you sure about that?
surely the opposite is true, otherwise how would it clean the whole rear screen? :confused:
Dec 19, 2006
673
The washer jet squirts on the rear screen and the wiper just moves the screen wash off the window cleaning it at the same time, some cars do have washer jets that move with wiper or sometimes they are on the wipers.
Also another thing to check if the rear washer isnt working is to make sure that the hose is connected to the pump on the washer bottle as my mates car had come off some how.
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
where in the boot do you need to check for this?
i had a look but could not find it and not eveidence of water and the pump is working
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
maybe it froze and you pumped it and the hose popped off. happened to me before. pain in the rear one to sort it.
