and the base coat
Great update mate, rebuild is coming on really well.
valve seals, are they Hi-temp ones? Ive been told that car like Audi TT & Leon Cupra R come wth different one to the ibiza?
these are the standard article,
from the etka I have it is the same part number as the BAM so other than that I dont know tbh...
got a bit of paint work sorted today
head is now white with a blue pearlescent high temp lacquer, rocker is a textured black which I am not totally sure about and am open to any opinions, might change back to flat...
wentmessing with the left overs of the blue peary too
so the rocker cover
the head
top meets bottom
next up is all the ancillaries.
getting there though!
ebay Joe,
the block will def be ok heat wise a thin coat of white paint will not make a huge difference on the head unless someone has proof to say otherwise.
ebay Joe,
Argh I looked on there at the time, bummer :(. Just a thought I haven't seen proof for or against it yet, obviously it looks better painted, hopefully that high temp stuff can take it ;). Have you got any particular power you're looking for or just a "clean" build?
clean build and we'll see what bill can do with it, not looking for an end figure really just want it to be EPIC fun!
install isn't too far away now, was delayed recently due to getting an electric Mitsubishi MiEV from work to use so have been messing about in it (looks horrible but is impressive for an electric car...). have filter housings, engine mount brackets and altenator etc back on now. neet to get some gasket cement tomorrow before the final closure of the engine. have decided on the theme for the engine bay now too so from here on in it will get "interesting"
pics tom
so the engine went in last friday and have 400 miles on it since. one small weeping oil cooler fitting which i need to take the bumper back off for. but other than that we are all good. due its first service already...
Engine was out in a moring and back in in a day but was a day rerouting the exhaust and stuff also. had a lift though so made things a huge ammount easier
Said I would upload a few pics to keep this going...
The last order arrives from SEAT
final assembly begins
Engine removed (Thanks lads)
FILTHY car
