May 13, 2007
1,017
Denmark
Hi
Last year I had a map from a danish mapper, back then I could experience "Red light flash from water temp gauge" when I had below 0 celcius. Back then I blaimed the map for being ****. Now I have revo, and I had this problem this morning.
What is this about, some cold/icy water warning or??
Vagcom dont show anything at all, and it will dissapear if I do a ignition off/on later when the car has been warmed up.
/Best regards,
You need to give the 2 prongs a scrape in the coolant tank with a screw driver that should clear it. It is usually just a buid up of scale on the prongs. Loads of threads on this it all ways happens.
Or change the coolant tank. They are very cheap from the dealers about £10 for the tank and £4 for the cap and permanently stops the problem.
I scraped the prongs last winter and it stopped it till this year when it came back again so i just changed the tank and its gone.
