Red oil light on dash
Beefy-Toledo
53
Hey guys i recently bought a 110 toledo tdi and on the dash when you start the car up the red oil light comes on and beeps 3 times. It then just stays on and flashes. The previous owner says that he put it on vag com and it come up as a sensor that goes in to the sump, so he replaced it and a little bit down the line the same fault occurred. The vw/audi breaker that he got the sensor off said that it was a common fault in the toledos. Does this sound about right or should i be worried. The car drives very well and has been serviced regularly.
kewe
814
Edinburgh
Taken from another thread in the Leon section but sounds like a common problem but not an obvious answer:-
More than likely the metal prongs which do the sensing in the coolant bottle are covered in crap - very quick solution is to take the top off the expansion tank (where you'd usually fill it up), get a long flat bladed screwdriver - take a look inside and you'll see (if it's similar to a LC anyway) 2 metal rods which go from the eletrical connector bit outside, through the case and into the coolant - give them a good scrape up and down the length of each prong and you're good to go.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Where exactly on the dash is this light situated, and does it light up a symbol?
I didn't think that oil level sensors were fitted to the 1.9TDI.
