i thought it was laggy too i can hear the turbo sppoling at just past 2000rpm and then it really kicks in just before 3000 rpm
i am out logging her tonight at about 8 so i would say about 10 i will have some logs on here if you guys are awake then
ryan_s3 said:
would have thought you would have seen more than 240lb/t with 1.5bar...seems a touch laggy.
At power engineering, the load was non existent on the rollers. Mine only did 270lbft at 1.45bar sustained. Runs were about 5 second only. The opperator only did 1 run on mine, as he said it wouldn't dip bellow 13:1 AF.
Odd, as it runs 12:1 on the road under full load. No bleedin load on the rollers.
Ignore the torque figures for the fwd cars from that day.
know what you mean wilko,there was no load put on the rear roller at awesome.
here are the logs i did last night
Group A: '002
RPM Load Inj. On Time Mass Flow
TIME
STAMP /min % ms g/s
196.75 3040 72.9 6.12 42.61
197.96 3320 174.4 13.94 138.72
199.06 4040 191.7 20.4 181.69
200.17 4680 180.5 17.68 173.72
201.28 5160 169.2 15.64 179.14
202.3 5560 166.9 14.62 173.39
203.2 5840 158.6 14.62 175.97
204.21 6160 153.4 14.96 180.08
205.3 5760 13.5 1.36 3.67
206.41 5160 191.7 19.04 198.61
207.42 5440 191.7 17.34 204.33
208.52 5680 185.7 17.68 197.47
209.64 5880 174.4 18.02 191.53
210.73 4560 15 0 8.28
211.64 4440 12.8 0 10.67
212.75 3480 12.8 0 8.83
213.75 3400 33.1 2.72 22.78
214.96 3320 57.9 4.42 39.14
oops quite a big cut and paste that one, but i also had the following fault code come up "16487 Mass air flow g70 too high PO103-35-10 Intermittent"
anyone know what that means
here it is again with rpm
RPM Absolute Pres. Absolute Pres.
/min mbar mbar
720 1340 1320
1120 2190 2400
1040 2190 2460
2360 2060 2300
1680 1950 2180
1800 1590 1070
2160 1000 1110
2640 1000 1050
1880 1000 1040
1880 1000 1030
2080 1000 1020
2320 1000 1010
2360 1000 1020
2360 1000 1020
2440 1000 1010
2600 1000 1010
2760 1000 1010
2800 1010 1000
2960 1000 1270
3440 1240 1070
4280 1480 1290
4920 1000 1060
5400 1030 1070
4360 1000 1100
3400 1000 1070
3200 1000 1040
3000 1200 1030
2800 1000 1330
1720 1180 1060
2560 1280 1230
3000 1000 1110
2120 1000 1060
1520 1000 1050
2000 1000 1060
1080 2030 1340
1600 2110 1830
2800 2130 2540
1880 2160 2480
2440 1000 1630
1800 1140 1110
1840 1000 1040
2000 1000 1060
2080 1000 1100
2120 1000 1030
2160 1000 1010
2360 1000 1020
1880 1000 1010
2000 1000 1010
2080 1000 1000
2120 1000 1010
2160 1000 1010
2200 1000 1000
2320 1000 1000
2560 1000 1000
2880 1000 1000
3360 1010 1010
3360 1440 1150
2840 1000 1170
2240 1220 1130
2200 1000 1520
2160 1340 1120
2040 1000 1050
2280 1360 1020
2080 1210 1310
1160 1060 1150
880 1160 1110
2320 1000 1560
1880 1000 1060
1040 1160 1040
800 1000 1170
720 1000 1050
760 1250 1120
720 2090 1570
1440 2120 2530
2160 1000 1510
2520 1000 1060
2080 2070 1180
2640 2110 1860
1920 2110 2540
2000 1000 1270
2040 1000 1050
2200 1000 1050
2360 1120 1130
2520 1190 1240
2720 1190 1260
2080 1040 1240
2080 1050 1190
2200 1200 1230
2280 1200 1270
2360 1210 1280
2600 1360 1420
2960 1590 1480
3080 1000 1340
2600 1470 1250
2640 1630 1740
2760 1000 1750
2920 2050 1390
2960 2100 2140
2880 2100 2540
2800 1000 1210
2800 1000 1060
2840 1000 1070
2840 1000 1060
2840 1000 1020
2840 1000 1070
2880 1000 1060
2880 1000 1050
2920 1000 1180
2920 1000 1100
3000 1000 1060
2760 1000 1040
2440 1000 1050
2480 1000 1130
2480 1310 1160
2520 1700 1690
2600 2190 2340
2720 2190 2340
2760 2190 2280
2720 2170 2220
2720 2150 2210
2680 1000 1640
3160 1000 1100
3160 1000 1050
3120 1000 1040
3120 1000 1040
3120 1000 1030
3120 1000 1030
3080 1000 1020
3080 1000 1020
3040 1000 1020
3080 1000 1020
3120 1000 1020
3200 1000 1020
3480 1000 1020
3760 1000 1020
4000 1000 1020
4280 1000 1010
4480 1000 1010
4520 1000 1000
3720 1000 1000
3560 1000 1000
3320 1070 1000
3120 1070 1090
3000 1140 1120
2920 1000 1200
2840 1230 1040
2760 1890 1380
2640 1390 1060
2520 1000 1140
2360 1000 1080
1520 1000 1020
2360 1150 1160
2520 1110 1220
2080 1070 1200
1040 1040 1220
840 1540 1400
720 2200 2540
720 2140 2430
760 2020 2250
1160 1940 2090
1400 1880 2010
1880 1830 1980
2440 1000 1850
1680 2020 2290
2400 1960 2160
2000 1920 2090
2080 1870 1940
2240 1000 1440
2640 1000 1090
2760 1000 1060
2840 1000 1040
2920 1000 1100
3000 1000 1110
3160 1000 1050
3840 1000 1030
4560 1000 1020
5040 1000 1020
5440 1000 1030
5760 1000 1100
6040 1000 1080
6360 1000 1850
5040 2020 2290
5360 1960 2160
5600 1920 2090
5800 1870 1940
5280 1000 1440
4480 1000 1090
3600 1000 1060
3400 1000 1040
3320 1000 1100
3280 1000 1110
3200 1000 1050
3080 1000 1030
2920 1000 1020
2880 1000 1020
2840 1000 1030
2840 1000 1100
2800 1000 1080
wierd thing is my car felt like it was flying 2 nights ago it felt smooth, last night it didnt feel the same is that where the car is just adapting to the map or not, simon put it on boost 7 timing 6 do you think i could up the timing and lower the boost looking at the timing on this next post
'020
Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
CF CF CF CF
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 3
0 0 0 3
0 0 0 0
0 0 0 0
0 0 0 0.8
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 3 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 1.5
0 0 0 1.5
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 1.5
0 0 0 0.8
0 0 0 0.8
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 1.5
0 0 0 0.8
0 0 0 0.8
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 3
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
also if my maf was saying that it was pulling 219g/s is there a chance that my car could have been running lean or rich dont know what one it would be i would say rich as there is more air going into it or is it nothing to do with that
I've seen 204 before, I've been seeing low-mid 190s, although I've not logged it since I cleaned my rather bogging filter...
Doesn't look like a gear change on that log though? 204 at 5400 which is where Ben's was high before.
That boost log doesn't look like you put your foot down anywhere :confused:
AFAIK, only if your MAF was reading wrong would you have a rich or lean issue. I would guess that your MAF is/was overreading, so it'll be running rich. You can log some other stuff to tell you if it's running rich/lean, but you'll need someone else to interpret the results :clown:
If your timing log was done at the same time as the boost log, it doesn't tell us much.
I'd leave it alone for a bit - I'm sure there's a reason they set it to B7T6. Although you could do what I did and try and log each setting and look at the results.
yeah i dont understand it at all, i understand that my maf must have been playing up to pull 219.36 and to be honest it did start to worry me as it was climbing each night i logged it. There isnt a gear change there as you can tell from the next 2 time frames.
The boost seems to be all over the place it doesnt look as if i gunned it anywhere and i have no explanation for that as you can see the rpm at the side to prove i was gunning it.
The timing is still good i havnt logged temps which is what i want to do as running more boost will increase temps wont it???
But i am going to leave it a few days let the car adapt and carry on logging to see what happens, does anyone have any idea what that fault code means??????
I didn't look at your revs :rolleyes: but it doesn't look like it was requesting any boost - I'm guessing it was in limp mode when you were logging, either because of the MAF code you mention, or because it overboosted (actual exceeded requested) which put it in limp mode and threw that MAF code.
If you do a search on that MAF code, it gets mentioned a lot with overboost situations, but with another code also thrown at the same time...
but it doesnt feel like it is in limp mode as i was holding off my mates s3 with revo stg2 last night albeit it is faster but mine was still holding it off so i dont think it is in limp mode
As phil said those logs you are just pootling along! You need to use the marker buttom at the start and end (or start and stop, what ever is easy then when you look at the logs it makes more sense) of a 4th gear run 40 - 100 so that you get to see consistant result, not this going through the gear stuff which confuses matters!
Also only log 1 block at a time to increase sample rate!
It might not have been when you raced your mate, but it was when you did the logs you posted.
there is no way it was in limp mode when i raced my mate as i raced 20min after i did the log without resetting it or turning the engine off, here is another log i did last night although it is only 12 sec long it starts in 3rd gear at the top of a slip road then into 4th, by the way is there any logs that i can do that will help solve is and what are the best conditions i.e uphill 40 - 100 in 4th or what? cheers
'002
/min % ms g/s
3320 72.9 6.12 48.08
3880 191.7 19.72 175.39
4600 191.7 18.7 183.42
5160 191.7 17.68 194.42
5680 188.7 17.34 203.31
6040 160.2 14.28 181.83
5640 12.8 1.36 2.06
5000 191.7 21.76 200.5
5280 181.2 17.34 181.72
5480 162.4 14.62 169.64
5680 158.6 15.3 173.11
5880 144.4 12.92 96.61
'020
CF CF CF CF
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
'115
RPM Load Absolute Pres. Absolute Pres.
/min % mbar mbar
3240 63.9 1000 1140
3680 191.7 2210 2360
4360 191.7 2180 2430
4960 191.7 2040 2260
5560 191.7 1930 2120
5960 166.9 1850 2170
6160 48.9 1000 1970
4840 154.9 2060 1860
5160 175.9 2000 2230
5440 169.2 1950 2140
5640 160.9 1910 1990
5800 156.4 1870 1990
