results of my rolling road run
Feb 22, 2009
3,618
South Wales
SUN POWER DIAGNOSTIC
Vehicle type : Seat Leon TDI 150
Engine type : Diesel
Reg Nr. : HN04 ###
Operator : Tommy
Date : 15.05.09
Time : 15:51
POWER DATA
Norm power P-norm : 167.5 BHP accord to DIN 70020
Engine output P-eng : 163.0 BHP
Wheel output P-wheel : 129.0 BHP
Drag output P-drag : 34.0 BHP
Max. power at 93mph or 3880 rpm
Torque M : 368 Nm
Max. torque at 55 mph or 2310 rpm
Max. speed ................: 98 mph
Max. RPM ...................: 4060 rpm
is this normal car is completely standard other than Miller DS4
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Near enough exactly the same figures I got.
Remap will give you 185-190 depending on who does it. Not necessarily about peak power its about how it holds through the range.
majesty78
490
Austria
Especially for a stock ARL engine those numbers are way to high.
You must be lucky if the engine reaches 150hp, most of them struggle at about 144-146hp.
Torque is also to high, but the OEM 330Nm are at least reached by most stock engines.
So this dyno is some kind of inacccurate.
Greets, Alex
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
hes pretty good , its yn abercynnon , south wales,
just my mates are big into chasing numbers on their cossies and said he wasnt accurate
pretty decent money for a run , gives you a fair idea will take mine if it ever runs again
Aug 1, 2005
2,695
Cullompton . Devon
Greets, Alex
Totally disagree with what majesty says. The number are on the high end of the scale but if you do a web search diesel VAG engine are well known to produce more then factory quoted numbers. Here is just a few examples
Seat Leon PD150 : http://www.superchips.co.uk/curves/vag150pd.pdf
VW Golf Mk6 2.0 140TDI : http://www.superchips.co.uk/curves/VW20TDiCR140PS.pdf
jonnie5
Seat Leon FR+
Mar 14, 2007
342
Rosyth
I went to a rr day at Dastek about 1 1/2 years ago. Totally standard running on V power I got 171.8bhp@4,137rpm 258lbft@2,132rpm. Being praraniod about dyno lottery........
Very next day I went to Star Performance and it made 165bhp 253lbfts. I got told by JIM that they get alot of PD engines producing higher figures than VAG quote for standard.
Posted the graphs before.
http://www.seatcupra.net/forums/showthread.php?t=146995
mjt
365
that's cool, but most dynos overread. so at least it's not under power :)
dynos are really only of any use for checking the power before and after modifying
mjthompson
Hi guys, i had my pd150 (05 plate, 35k miles) on the rolling road today (Circuit Motors @ Castle Combe).
As far as i know it is standard, apart from a green cotton panel filter and running on v-power.
From my results and looking round on this forum, i suspect that a previous owner may have had it mapped.
Here are my results (27 degrees c ambient temp)
Max power at flywheel - 177.6 bhp @ 4047rpm
Max power at wheels - 155.2 bhp @ 4019rpm
Max torque - 265.4 lbft @ 2754rpm
The other cars that were tested when i was there were as expected, or a bit under. There were 3 Clio 172's there and they all came off at 168 - 176bhp, spo i dont think the rolling road is giving optimistic readings.
The tester also commented on the amount of smoke being more than expected, which also points to being mapped, etc.
What do you guys think? What do you think has been done, map wise?
mjthompson
Where would this be located? What kind of thing am i looking for? Cheers
