Antera
Retrofitting Travel assist Seat Leon KL
asganaway2019
11
Control unit 09
Adjustments:
BCM Fahrerassistenz-Blinkfunktionen:
Travel_Assist_Blinken: active
in 09 I only have similar entry under:
adaptation
flashing function
travel assist
Wich i already activated for emergency brake assist
Control unit 44
Adjustments:
Qfk_ma_function:
Qfk_ma_function: activ
this is already set
Control unit A5
Adjustments:
Hc_variante: Variante_3 of Variante_5
HC_mob_line: coded
this is set to variante_5 and hc_mob_line already coded
thanks
asganaway2019
11
hello everyone, sorry for the delay in giving you feedback, I had a chance to better test the automatic lane change and it works all right, one question, what is the difference between Hc_variante 3 or 5? I tried with both and it works with both
thanks
timeclypse
Utrecht, The Netherlands
I want to retrofit the travel assist as well in the Seat Ateca (it looks like it shares the same steering wheel as the Leon). I currently own a Seat Ateca from 2022 (DSG, Xperience, paddles, heated steering wheel), and don't have the travel assist button.
However, i found a lot of different subtype numbers after the steering wheel number 5FA419091. For example: 5FA419091ESWW or 5FA419091EL.
What are the differences between those? And is it sufficient to just look at the steering wheel for the "main" functions as:
- Paddles
- Heating button
- Travel assist button
- Stitches colour
Or could anyone explain the differences? For now i am able to get a 5FA419091ESWW, so hopefully it will be sufficient.
witek_77
120
52
PL
5FA419091EL this is excelence
-Paddles
- Heating button
- Stitches colour (white)
timeclypse
