will also need to log block 020 so that you can see your CF's
Ok cheers karl and acid ill do the logs tonight and post the results up tomorrow night
lol how slow am i
yes mate the max boost your ecu is requesting is 2120 mbar which works out about 16.2psi
the max your engine is getting is 2150 mbar wcich is about 16.6 psi
time to turn the boost up i think,but keep an eye on block 020 (CF's) when doing this
OK cheers what do i need to look out for in the Cf's and what are Cf's sorry for being think but we all have to start somewhere![]()
the Cf's are corrections factors. ie when your ecu starts to knock the timing back to prevent detonation etc.
logging block 020 will let you see the Cf's the more you turn the boost and timing up the higher the cf will be. Really you dont want to see any Cf's over 3 IMO
also keep an eye on the induction temps when you up the boost....
