Such a good example of flash red. Will be using this as some inspiration on tidying up mine.
Finally after many years of wanting the optional Recaro interior, I finally have a set for mine. Only fitted the passenger seat as of yet. Hopefully will get round to doing the rest soon.
20151019_200532_zpsi5qz3qas.jpg~original
20151020_192331_zps5exxzdrp.jpg~original
20151020_195111_zpsj5vitvyt.jpg~original
Car will be SORN at the end of the month and will carefully be given a custom stage 2 map throughout the winter by a close friend. I say carefully because I want a spot on map, not to aggressive so it wheel spins in 1,2 or 3, and not to underpowered and lame. Just a nice useable map.
Been a few months since I last updated but there isn't too much to write about. The car will be taxed again this weekend and given a run as she does look sorry for herself on the driveway. Haven't done anything to her other than removing the washer bottle, new job has stopped me from spending temporarily.
If things flow financially this year then an evo is definitely on the cards towards the winter time. But I will be getting new shoes for the leon and am swaying towards JR11's as they're not overly expensive and look the part, except the multi stud centres which put me off slightly.
Anyway watch this space!
9 months since last update, should really update more often like I used to really.
Anyway a few changes have occurred over the course of the year, mostly under the bonnet and a few major mechanical things.
I've said previously that i'll be getting rid of this car etc. but I really can't part with her as I know this car inside out and I've been struggling to find a replacement. After 4 years of ownership I think another year and I will sell up.
Right onto the bits and bobs that I've done throughout the year.
First up was to de wiper the rear. I bought a kit from Killallwipers.com and was pretty simple to do. I found removing the trip a tad more difficult than actually de wipering.
20160409_144441_zpsfigiwihn.jpg~original
Removing the wiper motor.
20160409_150140_zpsgw1pjdey.jpg~original
And the finished look
20160410_150517_zpsajbv6rur.jpg~original
Next up was replacing the fuel hose which when taken off looked a lot worse for wear than I first thought.
20160423_143957_zpscmevkaeu.jpg~original
20160423_144023_zpsxsfpxsgr.jpg~original
And the replacement
20160423_152701_zpsxgvn0hg5.jpg~original
April this year I decided to change both rear calipers as the offside one was slightly sticking and was annoying me for a while. Most people that know me know I like replacing things in pairs hence opting for both calipers.
Before both calipers came off...
20160502_131008_zpsk3blj3ot.jpg~original
20160502_131036_zps0aouqoew.jpg~original
Nearside went on first of all.
20160502_173658_zps9klzc87s.jpg~original
20160502_173703_zpssqateoeg.jpg~original
Then the offside.
20160502_173710_zpsjxixfggm.jpg~original
20160502_173715_zpsmqfqozy3.jpg~original
Then both splashguards were painted with black hammered hammerite paint as the rust was starting to come through again.
20160506_183132_zpsuwjz1qkq.jpg~original
20160506_183143_zpsym0iqofd.jpg~original
I do have photos of the rear calipers painted after installation but can't find them as of yet. I used red hammerite spray paint rather than a brush on one this time, and the finish is pretty much OEM.
After so much time and effort preparing for the battery relocation I finally did it all in the summer. To be fair it wasn't that hard to do it's just the headache of running the 0 gauge wire from the front to back. It's well worth the time and effort though as it frees up so much space in the engine bay.
First was mounting the battery tray (bought from Amazon) into the spare wheel well. 5 holes drilled though and all mounted in place.
20160730_164551_zpsvm5m9ta0.jpg~original
20160730_164604_zpsltolfa9c.jpg~original
20160730_170104_zpss1cb58wo.jpg~original
I used a "French" designed quick release positive terminal as I do sometimes take the battery out to recharge as it sits on my drive quite often.
20160806_185542_zps9lbo2hfs.jpg~original
In July my clutch was finally changed, 95k and on stage 1 most of it's life I didn't think the original clutch would last that long to be fair, it was just slightly slipping in high gears hence why I thought it had to be changed. Went for a LUK OEM one as that'll cope on a stage 2 map when I get it done early next year.
In August I had my cambelt changed as this was just past the 4 years since it was last done. Opted for a Gates timing belt with the relevant tensioners and also a Ruville water pump, all changed by my mechanic. I have no photos of this as I left this to the experts. Another piece of mind as I hate leaving timing belts right to the last minute of when they should be changed.
Next up was a tyre change as my Vredesteins were shagged to say the least. I decided to go for Yokohama AD08r's as I've heard nothing but good reviews on these. Only had these on for 5 weeks and they seem pretty good so far but time will tell.
20160909_185901_zpsznbk4cst.jpg~original
20160909_185914_zpshrnp651q.jpg~original
Change of intake pipe was needed as i'm going to stage 2 next year and you can tell why I needed to in this photo lol
20160926_195700_zpsnp9wvwcw.jpg~original
I also needed to upgrade my air filter as well and thanks to a friend from my Leon Facebook group he kindly gave this to me.
20161005_181326_zpsrnpfl9e3.jpg~original
20161005_181331_zps4n6uvteg.jpg~original
And the finished article, this is what my bay looks like now and I am rerouting the air filter and building a new heatshield as we speak with an added cold air feed as well.
A Porsche oil cap was added to the bay, as well as more braided hosing for the brake servo, accompanied with some heat wrap cloth to protect the plastic one way valve which now sits nearer the turbo.
Gearbox was also treated to some silver VHT paint to freshen up the bay also.
20161008_175307_zpsa4ad5c0d.jpg~original
20161008_173829_zps3zwpd8o0.jpg~original
Rear number plate also needed replacing and opted for a gel one.
20160926_184013_zpszxfl99qp.jpg~original
20160926_184046_zpsch7kdxek.jpg~original
20160926_184000_zps2gcfyo02.jpg~original
Finally a couple of shots of how she stands now. There are tonnes of things that I've probably missed but as people know, I treat this car as my baby and have done for the past 4 years. Will be sad to see her go when I pluck up the courage to sell her. But I will be doing a few more bits in the mean time.
A front end respray will be on the cards as she's starting to show her age now. Also a new splitter is my next purchase.
20160924_165340_zpsn1upxapu.jpg~original
IMG_20160924_104732_zpsv1pi2qbz.jpg~original
This shot is just before I changed the number plate a few weeks ago..
20160924_165419_zpslehhhjgi.jpg~original
Thanks for reading!
Hey up Richy you still got the beast I still miss mine and wish I never sold it for the subaru as it cost me **** loads putting new engine in after crank failure hope your ok m8 I've just purchased a bmw m140i stay safe fella cupraRmark
Sent from my SM-G925F using Tapatalk
Hello Mark, it's been a while mate and hope you're well also!? Yeah I've still got her and she's still going strong. My mate was in the same boat with his Scooby and had to sell it in the end as it was falling apart lol.
Beemer looks very nice, that must shift quite a bit!
Yes m8 I just lost faith even though with the sti lump I fitted and 2k later I just let it go never ending so bought a new 1 series last year but wanted more than a 2ltr diesel... so thought what the he'll it's now or never m8 it's pretty Evil even whilst running in it seems full of beans and plenty of them m8....your R still looking sweet m8
It looks really nice mate, what bhp is she? I've always had a soft spot for the 1M BMW but they're rocketing up in value. Cheers by the way dude, I'm gonna try and get her in a few shows next year and then sell up and move on.
They are 345hp bit massive torque low down m8 good thing about the new ones is nearly 7k of list price in discounts....not many R about now might get the Mrs 1 next as we loved all 3 of mine and they are still reasonably priced
Jesus! That must shift big time! Do it mate, they're dirt cheap now but finding a good one is proving to be difficult as they're landing into the wrong hands. Buy mine next year ;) lol
Rich. The car looks so well in the pics. Shame it's pretty dead on here these days as yours deserve far more views than it has got!
Stunning.
