Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Hi All
I have attempted to install the rieger diffuser today however I have had to give up as I cannot get the old one off the bumper.
I do not want to damage anything by forcing it, I removed the 2 torx screws on the bottom and the push pins each side, the top clips do not want to budge.
Hi Mcewan
Unfortunately no pics of the install as it kept raining and I had to get it done pretty quick. The hardest part is getting the old diffuser off, on the OE diffuser there are clips all along the bumper, just start at one end and you need a fair bit of force. The Reiger diffuser just has locating fingers where the clips were, just push these in and while holding it insert the 2 screws underneath where the existing holes are, use the packers provided between the diffuser and car body, then take the 2 screws out of the car where the tip of the diffuser is use the longer supplied screws and spacers to fix each side. Then all that remains is to use a 3mm drill bit and drill through the holes in the diffuser to the sides by the exhaust tips, insert the 2 screws each side and you are done.
