Rolling road results
The_one
508
England
Well today i went to a rolling road at powerstation in Gloucester.
As today is so hot the temps even in the dyno room were high :( :( (29 degrees ambient)
Anyway i managed to pull
199bhp @ 4685rpm
235lbs torque @ 4015rpm
I think my power is down because of the high temps? What do people think from my log below which was done during the power run.
Shouldnt it continue pulling a bit more past 4500rpm? I didnt think even the k03 tailed off that early? :cry:
Code:
6K0 906 032 AA 		1.8L 20VT EU3       0002
	Group A:	'020				Group B:	'002				Group C:	'118
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Inj. On Time	Mass Flow		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 ms	 g/s	STAMP	 /min	°C	%	 mbar
	0.78	0	0	0	0	0	0	72.2	0.82	2.69	0.38	0	49	0	1020
	9.57	0	0	0	0	8.77	840	18.8	2.46	3.03	9.17	840	49	0	1020
	10.77	0	0	0	0	9.97	840	18	2.05	3.06	10.37	840	50	0	1020
	12.08	0	0	0	0	11.17	840	18	2.05	2.83	11.68	840	50	0	1020
	13.28	0	0	0	0	12.48	840	18.8	2.46	3.08	12.88	920	50	0	1020
	14.48	5.3	4.5	0	0	13.68	1360	21.1	2.46	5.64	14.08	1240	49	0	1020
	15.68	0	0	0	0	14.88	1240	30.8	3.28	6.92	15.28	1480	48	0	1030
	16.88	0	0	0	0	16.08	1800	30.8	2.05	4.53	16.48	1560	47	0	1040
	18.07	5.3	3.8	0	0	17.27	1240	50.4	6.15	12.39	17.68	1560	48	0	1040
	19.27	4.5	4.5	0	0	18.47	1600	18	1.64	3.03	18.87	1200	46	0	1030
	20.47	0	0	0	0	19.67	1560	57.9	6.15	17.33	20.07	1480	45	0	1120
	21.67	2.3	3	0	0	20.87	1160	63.2	9.43	22	21.27	1320	45	95.3	1080
	22.87	2.3	3	0	0	22.07	1640	87.2	9.84	29.33	22.47	1800	43	95.3	1250
	24.07	1.5	0.8	0	0	23.27	1960	100	11.07	38.89	23.67	2040	40	95.3	1440
	25.38	0	0	0	0	24.47	2280	124.8	13.12	56.67	24.98	2360	39	95.3	1770
	26.58	0	0	0	0	25.78	2560	160.9	18.45	83.31	26.18	2680	39	85.9	2180
	27.78	0	0	0	0	26.98	2840	169.2	19.68	92.28	27.38	2920	38	84.7	2190
	28.98	0	0	0	0	28.18	3120	177.4	21.32	107.08	28.58	3200	39	89.4	2280
	30.18	0	0	0	0	29.38	3400	183.5	22.55	124.47	29.78	3480	39	91.4	2300
	31.38	0	0	0	0	30.58	3680	182	22.96	130.25	30.98	3760	39	91	2320
	32.58	0	0	0	0	31.78	3960	184.2	24.19	141.22	32.18	4040	40	92.5	2300
	33.78	0	0	0	0	32.98	4240	181.2	24.19	146.75	33.38	4320	42	92.9	2220
	34.98	0	0	0	0	34.16	4520	173.7	23.78	150.42	34.58	4600	43	95.3	2110
	36.27	0	0	0	0	35.38	4800	169.2	23.78	155.53	35.78	4880	45	95.3	2020
	37.58	0	0	0	0	36.78	5120	163.9	23.37	159.89	37.18	5200	45	95.3	1930
	38.78	0	0	0	0	37.98	5440	154.1	22.96	158.58	38.38	5520	47	95.3	1870
	39.98	0	0	0	0	39.18	5680	145.9	22.55	158.67	39.58	5800	47	0	1470
The_one
508
England
Heres my power graph
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it's flowing 158g/s when you aborted the log.... so it's not "that" bad
they didn't rev very much though
The_one
508
England
Heres a log from road driving,
Doesn't pull any cf's on the road but as you can see pulled quite a bit on the rollers :(
Code:
Thursday	29	June	2006	22:17:47
	TIME					TIME
	0.97	0	0	0	0	0.57	2120	54.9	4.51	16.94
	1.77	0	0	0	0	1.37	2160	46.6	4.92	19.06
	4.26	0	0	0	0	3.86	2320	47.4	4.92	21.19
	5.16	0	0	0	0	4.76	2440	85.7	10.25	45.06
	5.96	0	0	0	0	5.56	2600	132.3	13.53	72.64
	6.76	0	0	0	0	6.36	2800	173.7	20.5	97.89
	7.67	0	0	0	0	7.16	3040	169.9	20.09	95.44
	8.56	0	0	0	0	8.18	3320	181.2	21.73	112.08
	9.36	0	0	0	0	8.96	3560	183.5	22.55	122
	10.16	0	0	0	0	9.76	3800	187.2	23.78	138.97
	11.06	0	0	0	0	10.56	4040	185.7	24.19	145.78
	11.88	0	0	0	0	11.48	4280	184.2	24.19	148.39
	12.87	0	0	0	0	12.37	4520	178.2	23.78	152.28
	13.67	0	0	0	0	13.27	4680	175.2	23.78	156.42
	14.47	0	0	0	0	14.07	4840	171.4	23.37	159.19
	15.27	0	0	0	0	14.87	5000	168.4	22.96	162.72
	16.07	0	0	0	0	15.67	5120	165.4	23.37	162.44
	16.87	0	0	0	0	16.47	5240	161.7	22.96	160.94
	17.67	0	0	0	0	17.27	5320	157.1	22.55	159.31
	18.47	0	0	0	0	18.07	5440	154.9	22.55	159.39
	19.36	0	0	0	0	18.96	5560	150.4	22.14	157
	20.27	0	0	0	0	19.87	5640	147.4	21.73	157.56
	21.07	0	0	0	0	20.67	5720	146.6	21.73	158.36
	21.87	0	0	0	0	21.47	5760	145.1	21.73	158.94
	22.67	0	0	0	0	22.27	5840	143.6	21.73	158.94
	23.46	0	0	0	0	23.06	5880	140.6	21.32	158.36
	24.26	0	0	0	0	23.86	5960	139.8	21.73	159.78
	25.07	0	0	0	0	24.66	6040	139.8	21.73	160.06
	25.86	0	0	0	0	25.46	6120	136.8	21.73	160.61
	26.66	0	0	0	0	26.27	6040	6.8	1.23	2.75
	27.46	0	0	0	0	27.06	5880	9	0	11.28
The_one
508
England
Mate on the road it pulls NO cf's back whatsoever im only runnin timing 4, need to to put the timing up to be honest, im sure its pulling back because it was roasting in the dyno room :(
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
look at airflow & rpm
they don't rev it past 6k on the log
however peak airflow looks similar on the road vs rollers
pulled back because of heat & timing I guess, what inlet temps would you expect to see on the road?
The_one
508
England
When i've logged on the road i haven't seen above 42 degrees so far.
On the rollers it hit a max of 50
The_one
508
England
yeah the inlet temp was 50 degrees at the start, as soon as run started it went down to about 45 then went back up to 47/48
