brasso88
right done a few logs on my cupra, was from 2nd gear into third, dunno how good the data is just woundering if anyone can make out if anything is at fault from this like my maf or lambda, or can point me in the right direction to what i should be checking, basicaly my car is running like **** it seems to have lack off top end power when on boost and feels asif i have a misfire in the top end off the rev range, it only done this when i changed the maf for another 1 which i know come off a working car with no probs, if i put the old maf on it just keep throwing up fault code p1128, any helf or advice would be great as i dont have the money spare for labour costs to stick it in the garage atm
Group B: '001
RPM Temperature Lambda Bin. Bits
TIME
STAMP /min 蚓 %
0.25 1440 90 -3.1 11101011
0.85 1560 90 -2.3 11101011
1.45 1760 90 -2.3 11101011
2.05 1920 90 0.8 11101011
2.65 2160 90 0 11100001
3.25 2480 90 0 11100001
3.85 2800 90 0 11100001
4.46 3160 90 0 11100001
5.06 3560 90 0 11100001
5.65 3960 90 0 11100001
6.26 4360 90 0 11100001
6.86 3960 90 5.5 11110101
7.45 3440 90 0 11100001
8.05 3080 90 0 11100001
8.65 3240 90 5.5 11100001
9.25 3400 90 20.3 11100001
9.84 3560 90 25 11100001
10.45 3680 90 25 11100001
11.04 3800 90 25 11100001
11.65 3000 90 0 11110101
12.24 2800 90 0 11110101
12.84 2600 90 0 11110101
Group C: '002
RPM Load Inj. On Time Mass Flow
TIME
STAMP /min % ms g/s
0.55 1480 61.7 6.97 18.53
1.15 1680 65.4 6.97 20.78
1.75 1840 60.9 6.56 21.36
2.35 2040 86.5 10.25 36.81
2.95 2320 103 12.71 48.81
3.55 2640 112.8 14.76 58.11
4.15 3000 121.8 15.99 71.39
4.76 3360 138.3 18.04 92.56
5.36 3760 151.9 20.91 110.97
5.96 4160 146.6 20.5 117.69
6.56 4360 150.4 20.91 125.33
7.16 3560 11.3 1.23 0
7.75 2960 109.8 14.35 69.58
8.36 3200 136.8 18.45 87.47
8.95 3360 153.4 23.78 99.72
9.54 3480 161.7 27.88 109.17
10.15 3640 160.2 27.88 111.72
10.75 3760 158.6 27.88 112.97
11.35 3440 34.6 2.46 0
11.94 2640 16.5 2.87 17.97
12.54 2720 6.8 0 2.75
13.15 2520 8.3 0 4.17
well will give it another go 2moro, its a mk3 cupra, ko3s turbo front mount, forged valve and tip, cat back, cone filter and has been remapped but duno who by tho. what blocks on vag com are good to take readings off as i only have the free version atm. i know block 002 does the maf, but what other block if any could i read some data
Blocks 002, 020, 115, 003, 031, 118 pretty much cover everything.
On that spec, it looks like your injectors are maxed out. Maf is very low but that's probably because you didn't run all the way to the redline
Tbh I haven't looked to see what injectors ect is on it, I've ain't had the car long and also didn't get bigger all paper work with it, any way off telling what injectors and fpr is on it if u know what I mean?
right plugged my car in today and had a new fault code ive cleared code and it hasnt come back yet? do u think this could cause my running problems
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
also did a log in 3rd hopefully its a bit better ran out off ? when it reads high on lambda is when it starts struggling for power a dies off and seems like it missfiring?
Group B: '002
TIME
STAMP /min % ms g/s
0.3 2000 45.1 4.92 17.44
1.2 2080 71.4 10.25 33.61
2.1 2280 98.5 12.3 47.11
3 2560 119.5 15.58 60.39
3.9 2840 134.6 17.63 74.89
4.8 3160 141.4 18.45 86.47
5.7 3480 163.9 22.14 108.5
6.6 3800 160.9 22.14 117.86
7.5 4160 152.6 23.78 121.42
8.4 4360 157.1 28.29 130.64
9.31 4600 153.4 27.88 135.94
10.21 4800 149.6 27.88 136.61
11.11 5000 146.6 27.47 138.25
12.01 5240 142.1 27.06 142.61
12.91 4680 13.5 1.23 0
13.79 3840 6.8 0 4.75
14.69 3520 9.8 0 6.56
15.59 3280 9.8 0 6.11
16.49 3040 9.8 0 5.61
17.39 2840 9.8 0 5.31
Group C: '001
TIME
STAMP /min 蚓 %
0.6 2040 87 -4.7 1101001
1.5 2160 87 0 1100001
2.4 2360 87 0 1100001
3.3 2640 87 0 1100001
4.2 2960 87 0 1100001
5.1 3240 88 0 1100001
6 3600 88 0 1100001
6.91 3920 87 0 1100001
7.8 4240 88 20.3 1100001
8.71 4440 88 25 1100001
9.61 4640 88 25 1100001
10.51 4880 88 25 1100001
11.41 5080 88 25 1100001
12.3 5280 88 25 1100001
13.2 4200 88 0 1110101
14.09 3720 88 0 1110101
14.99 3440 88 0 1110101
15.89 3200 88 0 1110101
16.79 2920 88 0 1110101
17.69 2760 89 0 1110101
when your car is on cruise and idle does your block 001 sit at +25%?
malfunction in circuit error is the cause..
try lambda first, but I fear there is another electrical gremlin which will continue to cause this overfueling..
resistor mods being high on the *possible* list having damaged the ecu output stages..
not yet found a fix for this on the several ibiza's I have found this one
Will check it on idle, it's still got the valves plugged in ATM, haven't put resisters in yet, and it was running lean before I changed maf.
