Stringman
66
Hi All
the sat. nav in my 2019 Leon has started acting very weird.
I will set a route and start following it and then I can hear clicks ( like someone is touching the screen) and things will change- for instance a n address marker just popped up and asked if I wanted to navigate to it. then the existing route stopped until I pressed the little car icon on the right.
Its just like a ghost is touching/playing with the screen!
It did this about 3 times in a 10min journey.
Any ideas on what could be causing it?
It sounds like the touchscreen might be damaged, but I'd start with rebooting the infotainment system. Press and hold the power button, and keep it pressed until it powers off and then it will come back on, then release the power button.
Thanks for that.
It only seems to do it first thing in the morning when its cold. But I will try rebooting it.
If it does turn out to be a faulty screen - it is not silly money to have it replaced.
Thanks for that.
Mine occasionally does the same, first thing and usually only when it's raining or damp outside. Stops after a few minutes but suspect it's the touch screen on the way out as already suggested earlier.
Sent from my SM-S908B using Tapatalk
Thanks for that.
It was a bit of a known issue when the weather gets colder and damper. Mine went through a stupid phase about 3 years ago but finally sorted itself out.
Don't know if it's worth trying to clean the screen. You've not be touching it with oily/sticky fingers?
Thanks for the replies.
I have spoken to the seller (Skoda dealer) who are looking into.
I will check the firmware version and also try wiping the screen with a cloth as suggested.
But no sticky fingers etc
This has happened to me too. I found that the screen had condensation on the front and after drying it off, it was fine.
It seems to be a common problem caused by condensation on cold mornings. Had it on two out of the four Leons we've had. I think giving the screen a wipe with some sort of screen cleaner might help but I'm guessing.
THanks guys.
I actually managed to film it to send to the dealer.
I wiped the screen before I started the car ( it wasnt damp) At first it was very unresponsive to the touch, then after 2 min it stared to do its random switching !!!
THanks guys.
You night get the screen replaced. depends on how good the dealer is. I think we had one replaced but it was years ago, I forget. I remember taking videos like you have.
Dealer has come back to me saying that that have found some who will replace the digitiser but wants the car for a few days.
This is a huge pain as they are over 100m away.
I am tempted to say that I will remove the unit myself. Presumably the car is still driveable without the touchscreen?
I doubt they'll let you do it yourself. Do you have a closer dealer that could do it?
Sadly not as its not new its from a dealer in bognor. To be fair they have been pretty good considering it is secondhand. Legally they have to repair it with inconvenience to myself which means(in my book) them picking up the car with a replacement, sorting it out and returning it. I feel thats a real pain for everyone, so If its easy to remove I will suggest that
It's a bit of a PITA to remove the facelift screen, it can only be done by removing the vent assembly and operating the spring loaded lugs that secure the screen to the surround.
