SAT NAV radio station bug
bcroninuk
23
When I have the sat nav on, the steering wheel left and right buttons (which I have set to change radio stations) do not work as programmed. Instead, when pressed to change stations, it will attempt to go to the next station but will only stay on the same station. Any software or update to fix this annoying bug?
Mr Pig
2,628
910
There is another thread on info-centre bugs, they are annoying a lot of us. Lost my radio pre-sets again yesterday. The system is clearly not the best.
stu_m
613
40
Hull
www.themotorbikeforum.co.uk
pretty sure it only scrolls through the presets so if you only have one preset then it will just go back to that one
having the display between the clocks on audio then using the right scroll wheel allows you to scroll through all DAB stations
