Ahhhh, i get you now xd !, post #48 is a diagram of the back of the radio. So pin #3 is second from left (top row) on the connector that goes into the radio !. I should have been shot at birth !! - sorry for being thick !!!
Andy
cheers xd, lee and everyone who helped. Might just have saved a fortune in repairs if the radio had caused some issue to the kline there !. Incidentally what is the worst that could happen if i left it the way it is ?
Andy
On second thoughts. - I dont think you have a wire into pin 3 in your cars wiring. If you do, cut it as said. If not ...
It seems the radio is using pin 7 for the telephone mute as the ISO telephone mute (pin1) is to be used as speed sensor for the radio and by Seat.
Pin 2 is used by seat for telephone mute
But pin 7 is your permenent +12V that should be reconfigured through the adaptor to pin 4. Therefore the radio when muted is somehow messing with your car.
Switched supply is going to pin 4 which should be a permenant supply.
You need to get the permenant supply to pin4 instead of pin 7.
Your best bet really is to get the adaptor or just ensure pin 3, 2 and 5 (if not using the antenna amplifier) are not completing a circuit
I suggest you just dont mute the radio and turn it off to mute it rather than all this messing.
Thanks xd ! - actually i've just found this page in the manual. This is the setup for my radio. Does help any ??
Best Regards,
Andy
Yeah.
You need to cut and swap the wire going into Pin 7 with the one going into Pin 4.
Swapping permanent and switched 12V. Just so memory is retained by the radio
If there is a wire in Pin 3. Cut it.
Cut wire in Pin 2 - if you do not want to use the telephone mute function.
Also, remove any top connectors (C block) and leave unconnected. You wont need them.
I assume you have tried this when driving the car or with the car engine running.
The scangauge will shut down if you put the car to just the ignition after it running. It doesnt turn on either until the car is started.
Yeah if it actually went to a sub. But the cars wiring uses it for the K-Line (car diagnostics) which is the problem as described on the ross-tech website. So by not using the adapter you are getting an output on this and this will cause a problem.
Oh, firstly try if possible to disable the sub-out and see if that fixes it. May disable the output on pin 3.
Hi, well i've just swapped the permanent +ve and +ve ignition over and the illumination bit is now fine!. Put it back together, scangauge didn't work. So i disconnected wire to Pin3 (sub woofer) and HEY PRESTO !!! scangauge now works as it did before !! - so you were right, it was to do with the wire on Pin3 (sub woofer). Virtual pint on xd and yee all who'v helped !
Well off topic but i've just noticed while i've been on with all this that the exhaust is kicking out a bit of smoke (which i've never seen on a hot day !), not black or anything like that, just looks like a car on a cold morning (not quite as much smoke as that tho), and spitting out spits of water (i presume it's water) on revving to about 3000 rpm, is that normal, or is it just me being paranoid yet again ??
Regards,
Andy
i've now moved this thread over to the proper group. Which is what i should have done in the first place!, Sorry !!
Andy
Good stuff. Glad you go it sorted out.
Hows the calibration going?
The amount of stuff now i have to note when filling up is huge. But should be cutting that down after a few more tanks. Calibration seems to be just about right.
Haha, well the bad thing is, in my confident wisdom that a reset would get the Scangauge working again i reset it !! (stupid boy !!), now i have to start again with the tank refills !! - i had gotten up to about 5 or 6 refills, but i'm gonna have to start again !!!! hmmmmm
What did you say you had your offset stored as ??
Tank size: 12, Speed calib: -2 (are these right ?)
Best Regards,
Andy
Cheers Xd! - i'll get the cutoff set to 5. Wouldn't care i only just filled up yesterday morning with £52 worth of petrol at 119.9p/l, then the damn prices went down to 115.9 in the afternoon !!!! - just typical !
Andy
Hi there !! - had my scangauge quite a while now and wondered if there were any new codes out ???. Would like to know if the g-force gauge can work on the Leon ???
Looking at the cleanmpg forum there looks to be a wealth of new codes on there, but unclear if they also work on the Leon ??
Here, to list but a few:
GAUGE: Solicited Traction SOC
CONF?: Yes, confirmed
UNITS: Percentage of Full charge
->TXD: 07 E3 21 CE
->RXF: 05 61 86 CE 00 00
->RXD: 30 08
->MTH: 00 0A 00 02 00 00
->NAM: Sts
NOTES: Solicited / Active gauge, so first char upercase
GAUGE: Passive Traction SOC
CONF?: Yes, confirmed on SG FW version "3.15" only not "3.15*"
->TXD: 03 C3
->RXF: 01 03 82 CB 00 00
->RXD: 20 10
->NAM: pts
NOTES: Passive gauge, so first char lowercase
GAUGE: Solicited L5 SOC
->TXD: 07 E3 21 CE
->RXF: 05 61 86 CE 09 00
->RXD: 30 08
->NAM: Sls
NOTES: Solicited / Active gauge, so first char upercase. RXF is looking for '00' in byte nine. For the traction battery this is the LSB for the battery current which would always (99.61%) read non-zero.
GAUGE: Passive L5 SOC
->TXD: 03 C3
->RXF: 01 03 82 CB 08 00
->RXD: 20 10
->NAM: pls
NOTES: Passive gauge, so first char lowercase. RXF is looking for '00' in byte eight. For the traction battery this is the temperature reading of the battery. It will only read 0 celcius, when it really is 0 celcius in the battery conpartment. GAUGES
GENERAL
GAUGE: BOOST (TURBO)
CONF?: YES - 2001 Jetta TDI
UNITS: PSI
->TXD: 68 6A F1 01 0B
->RXF: 04 41 85 0B 00 00
->RXD: 28 08
->MTH: 00 91 00 64 FF 71
->NAM: BST
NOTES: THIS WORKS FOR TDIs, NOT SURE ABOUT GAS TURBOS, IT USES MAP. REPLACE FF 71 (14.3 PSI) WITH 2'S COMPLIMENT OF LOCAL ATMOSPHERIC PRESSURE IN PSI (YOU CAN ADJUST THE NUMBER SO BOOST IS 0 AT IDLE). MATH IS #*145/100-143 (CONVERTS KPa -> PSI), SUBTRACTS ATM PRESS IN PSI
GAUGE: HORSEPOWER (GAS)
CONF?: YES-INSIGHT, ...
UNITS: HORSEPOWER
->TXD: 00
->RXF: 40 00 80 00 00 00
->RXD: 00 00
->MTH: 00 0A 00 17 00 00
->NAM: HPW
NOTES: THIS IS FOR GASOLINE VEHICLES ONLY, MATH IS #*10/23
GAUGE: INSTANTANEOUS MPG
CONF?:
UNITS: MPGus (OR LPK OR MPGuk DEPENDING ON SETTINGS)
->TXD: 00
->RXF: 80 00 00 00 00 00
->RXD: 00 00
->MTH: 00 01 00 01 00 00
->NAM: iFE
NOTES: OTHER TRIP GAUGES ARE SIMILAR, MODIFY TXD ACCORDING TO SG MANUAL
GAUGE: Manifold Air Flow
UNITS: g/s (0 TO 655.36)
CONF?:
->TXD: 68 6A F1 01 10
->RXF: 04 41 45 10 00 00
->RXD: 28 10
->NAM: MAF
NOTES:
FOR THE FEH...
(See vehicle specific link for more)
Corrections to LL Gauge coding:
GAUGE: Cylinder Head Temp
UNITS: Degrees F
->TXD: 07 E0 22 16 24
->RXF: 04 62 05 16 06 24
->RXD: 30 10
->MTH: 00 02 00 01 00 00
->NAM: CHT
NOTES:
MPH TO 1 DECIMAL PLACE !
mph xx.xx
TXD: 00 BC
RXF: 01 00 42 B4 00 00
RXD: 38 10
MTH: 08 D8 0E 93 00 00
NAM: mph xx.xx
Left / Right GForce
TXD: 00 2A
RXF: 01 00 02 22 00 00
RXD: 10 10
MTH: 00 01 00 01 FE 00
NAM: LRg
Front / Back GForce
TXD: 00 2B
RXF: 01 00 02 23 00 00
RXD: 10 10
NAM: FBg
Alignment (stear left / right)
TXD: 00 2D
RXF: 01 00 02 25 00 00
RXD: 10 10
NAM: Slr
Break Pedal Position
TXD: 00 38
RXF: 01 00 02 30 00 00
RXD: 30 08
MTH: 00 64 00 80 00 00
NAM: BPs %
Left / Right GForce
TXD: 00 2A
RXD: 10 10
NAM: LRg
Front / Back GForce
TXD: 00 2B
RXD: 10 10
NAM: FBg
TXD: 00 2D
RXD: 10 10
NAM: Slr
TXD: 00 38
RXD: 30 08
NAM: BPs %
Battery AMPs (passive)
TXD: 00 33
RXF: 01 00 82 3B 00 00
RXD: 14 0C
NAM: bta
GForce to Right x.xx
TXD: 00 2A
RXF: 01 00 42 22 00 00
RXD: 10 10
NAM: gfr
GForce to Back x.xx
TXD: 00 2B
RXF: 01 00 42 23 00 00
RXD: 10 10
NAM: gfb
Stearing (degrees left) xx.xx%
TXD: 00 2D
RXF: 01 00 42 25 00 00
RXD: 14 0C
MTH: 00 64 01 BC 00 00
NAM: sdl
Break Pedal Position xx.x %
TXD: 00 38
RXF: 01 00 22 30 00 00
RXD: 30 08
NAM: bps
TXD: 00 33
RXD: 14 0C
NAM: bta
GAUGE TXD RXF RXD MTH NAM Notes
State of Charge 07E321CE 056186CE0000 3008 000A00020000 SOC %
Battery Voltage 0033 0100023B0000 2010 000100010000 BTV HV Battery Volts
Battery Current 07E321CE 056186CE0000 3810 0001000AF333 BTA HV Battery Amps
GForce to Right 002A 010042220000 1010 00010001FE00 gfr x.xx G's scaling a guess
GForce to Back 002B 010042230000 1010 00010001FE00 gfb x.xx G's scaling a guess
Stearing 002D 010042250000 140C 006401BC0000 sdl Degrees left xx.xx %
Brake Pedal Position 0038 010082300000 3008 006400800000 bps xx.x % depression
Battery Current 0033 0100823B0000 140C 000100010000 bta Passive CAN request
Kilometers per Hour 00BC 010042B40000 3810 03E804000000 kph xx.xx kph
Miles per Hour 00BC 010042B40000 3810 08D80E930000 mph xx.xx mph
Gas Pedal Position 024C 010282440000 4008 000A00020000 gps xx.x % depression
State of Charge 03C3 010382CB0000 2010 000A00020000 soc Passive CAN request
Battery Temp (upper read) 03C3 0103023B0000 3808 000100010000 buc °C max for the 5 ms cycle
Battery Temp (lower read) 03C3 0103023B0000 3008 000100010000 blc °C min for the 5 ms cycle
Battery Voltage 03C5 010302CD0000 2010 000100010000 btv 3CD pid reading
Ignition degrees before TDC 052E 010502260000 1810 000100010000 ign Passive CAN request
EV Button Status 0521 010522290000 3101 000100010000 evb EV button ON or OFF
Engine Coolant Temp 0525 0105822C0000 1808 000A00020000 wtc xx.x °C
Gas Gauge 05AC 010582A40000 1808 006400040000 gas xx.x % full
Best Regards,
Andy
There is nothing new there for the Leon and just about all of them are for Prius or Ford cars.
The ones that do apply (MAF, bHP, Boost for TDI, Inst MPG) have already been listed on the first page.
Havent been able to find anything new for a while
Cheers XD ! - yep, i just learned the hard way ! - i programmed about 10 of them in and none of them worked :( !! - Nevermind !
Best Regards,
Andy
Hey,
Has anyone found a code to get boost to work?
I'm getting a scan gauge from a friend of mine,what are the best gauges to use with the scan gauge?
Thanks...
Scangauge 2
Hey guys,
I'm buying my mates scan gauge off him soon,does this just plug straight into the ECU? obd II port I have been told? Is this right?!! Where abouts is the ECU located? :)
