Sep 21, 2020
7
Hi guys,
Need to replace my car battery. Had a couple of questions:
1. Are there any additional steps we need to do for Start Stop Cars? Never replaced a start stop car battery before hence just wanted to check - Getting mixed views of what needs doing with some videos saying nothing additional required.
2. What is the original OEM battery that comes with the car?
FYI - For the 1.2 TSI
Thanks.
Hopefully I can help you out here: My own 1.2TSI had a battery change 2 years ago, before I got the car, and the previous owner had put a bigger capacity battery on in its place. I had noticed that the start stop was a bit flaky, and when I checked on VCDS, in address 61 Battery Regulator, the battery was still coded for the old capacity. Any change to the AH and/or CCA rating needs to be recoded to keep the battery management system working as it should, and if an OEM battery is put on, then there is the facility to change the serial number of the battery too. Recoding mine instantly cured the start stop issue I had.
Generally, a new battery just needs the serial number tweaking by +1 (I always change this whether or not the replacement actually has a serial number on it), and the AH and CCA settings checked, and changed using VCDS - again VCDS address 61 Battery Regulator.
The radio code is stored in the instrument cluster, so the car remembers the code after the battery has been disconnected. But the dashboard computer will reset, and you will need to reset the one shot up and down of the drivers door window by working the switch and holding the switch for a few seconds in both the fully up and fully down positions. Personally I use a battery saver plugged into the diagnostic port, which keeps power to the vehicle's systems whilst the battery is disconnected, so resetting things isn't needed.
The OEM battery on my Toledo 1.2TSI Nav was a 59AH/320CCA spec. It was replaced with a 60AH/560CCA spec.
Hope this helps
Reactions: 249mat
I had to change my battery in august 2024 (8 years after car purchase) It was a Varta for with high start current (for cars with start-stop system). Can't remember the exact figures. I bought a Bosch with 700+ amps start current (about 250€) and changed it myself. A couple of weeks later I had a problem with one of the smart engine glow plugs and I had the check engine sign lit up. When I went to the official service, I told them about the battery replacement. They changed the plug (160€) and they wanted to calibrate a sensor for the start stop system, which should be on the positive cable near the battery. They were surprised that my car actually doesn't have a start-stop system, and thus no sensor to calibrate.
Summary: If you have a start stop system and you change the battery, probably there is a sensor to re-calibrate.
Toledo mk4 2016 - 1.6TDI Style FR
There is no sensor to recalibrate on the start stop. What they said needed doing was coding the new battery in, nothing to do with start stop, which involves telling the ECU of any change in power and capacity figures, and a change of serial number, basically telling the car that a new battery is fitted. If you didn't recode after you put the new battery in yourself, that's where your problems lay
well they didn't do anything with the car after they saw there was no sensor near the battery. And I had no other issues afterwards.
So either they did it beforehand without telling me, or the car handled the new battery without any changes. I don't know. I'm not an expert in car repairs. But their story sounded plausible.
