FRSJack
17
14
Hi all,
I have installed or will be installing an aftermarket reverse camera, I have done the coding using the OBD11 to bring the camera up on the infotaminfot screen. The trouble is, when I come out of reverse gear the reverse camera stays on for a while after. Is this because I don't have parking sensors installed from factory and it usually shows the park pilot screen after you come out of reverse gear, hence why it takes about 4 seconds before it switches off the camera screen?
If this is the case, is it possible to change a setting to fix this?
Kind regards,
Jack
