Use the search thing for more info, there's loads of threads which get really detailed and will help :) but the long and short of it is that it's down to personal preference.
Split R is 50% recirc & 50% blow off so can be quite loud and 007P is fully recirc. The 007 does get loud with a remap and open cone air filter however.
If you expressly want a 50/50 valve then the Turbosmart Kompact Dual Port comes highly recommended over the Split R. Remember that if you set the 50/50 valves too loose or block off the recirc port, you will most likely get limp mode. It's also worth notic that you can block the atmospheric port on a 50/50 to make it fully recirc but if that's what you want, i'd recommened going for a proper one.
If you expressly want a 50/50 valve then the Turbosmart Kompact Dual Port comes highly recommended over the Split R. Remember that if you set the 50/50 valves too loose or block off the recirc port, you will most likelt get limp mode.
Cheers for that mate i think im going to go for the 007p not to keen on the woooosh sound lol
i have had both. split r made me go in limp mode all the time, that was running it 50/50. now im using the 007 and its perfect. no probs at all. :)
ive had a few dv's had the baileys fully recirc, was good, but couldnt change the spring, had the split-r sounded good, threw a fault up, so i went for the 007, again very similar to the baileys, then went for the turbosmart dual port, this sounded brilliant, was louder than the split-r and didnt throw a fault up. now back on the 007 only because i heard it performs better.
it all depends on what you want plus some cars have had probs with the split r and the turbosmart but then some havent.
"Seat leon cupra, SPLIT-R or 007P which is better??"
:D
ive just got my cupra R, same engine basically, just i got bigger turbo :p hehe and id say go for the 007p mate ;)
