olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
just a quick remender to anyone that made the same mistake that i did...
found the other evening when going to check tyre pressures that my metal valve caps had corroded on with all the grit and salt over the past month or so. when i say corroded i mean after sethering two of the valves i gave up with the two pairs of pliars it took. so that was another £20 i could have done without spending.
just thought it worth a 'go and have a look' message!!
total utter dim whit!! [:@]
You should allways spray new dust caps with a bit of wd40 or simillar before fitting this helps with sticking later
Sorry to ask but was is sethering?
