Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
Right Im a total nub. I tried fitting the fog light kit today and well did great up till the wiring into the car part. I cant get the cable into the car although there r gromits on the wire. Where do I put it through and which conenction do I plug the single wire into presuming the positive (looks like it should go into the wiring in the dash but which 1 there numberd). Really confused any help much appreciated
grommet on the top right if the engine bay then look for the same colour wire in the haedlight switch think its light blue nd white remove the one in the switch and replace with the new one! the wiring is in place for fog lights in the switch but not in the engine bay
sorry chap I can't help with the wiring as I can't see a wiring diagram
the wire through the gromit thing is easy, get a wire coat hanger and bend a very tight loop into the end. spray wd40 around the gromit.then tie thin string through the loop and push the coat hanger through the gromit and pull the string through
then tie your wire to the string and pull that through too
always cover the joints of coat hanger/string/wire with tape to help it through the gromit
good luck
I gave up trying to do this and got a professional to do it who actually fits them for my local seat dealer. £80 all inclusive to fit it
thanks lads, o and how do I get the wire from the right of the engine to the left by the drivers side? bit new to this. O and the kit gave me a new switch do I still swap the wires and not add it in?
