Service Intervals
chewittgti
Hi Guys,
Ive got 16v Gti Cupra sport and was wondering what the service intervals were and what was needed at each one.
at present the car has done just under 80k and the light for major service is flashing,
what does a major service entail??
cheers.
SpareMan
354
If you searched the forum you would find the answer easily enough
All SEAT's are on 10K or 1 year service interval
Every 10K (or 1 year) is oil change and oil filter + inspections
Every 20K as 10K plus pollen filter
Every 40K as 20K plus air filter and fuel filter possibly.
SpareMan
354
I just knew cambelt would come up. This is a petrol car not diesel
Chewitt, the cambelt should be inspected on any VWG petrol model from 60K onwards and changed if required, it must be changed by about 110K. However I concede that for the age of your vehicle it should have been changed at 5 years if it wasn't
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
SpareMan said:
...VWG petrol model from 60K onwards and changed if required, it must be changed by about 110K.
I think I'd list 'Russian Roulette' as top of my hobby list if I'd taken a VAG petrol engine over 100k miles on the original cambelt :scary:
chewittgti
hi, the cambelt was changed at 60k so that has been done!
although i think i will give it an inspection just to clarify.
SpareMan
354
You think VWG would list this for ALL petrol models (VW, Audi, SEAT, Skoda) if they continually failed before then?
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
Yep.
Their ultimate aim is to keep the fleet buyers sweet, and don't give a monkey's about private buyers. If you take a typical car doing 12,000 miles a year, thats 8 years of driving to get to 100k. The belt goes - what are VAG going to say - 'here, have a new engine on us'. I think not. More likely 'It's 5 years out of warranty - your problem'
A fleet car will have long been disposed of by 60k. Fleet buyers then don't have to load their costs with a replacement belt.
Same thing with variable service. All designed to keep maintenance costs down for the fleet buyer so the cars are cheaper to lease. It's the poor private buyer who has to pick up the pieces when they get the car second hand at 3 years / 60k with only 2 oil changes and no cambelt change.
The car leasing firms have unbelievable clout with manufacturers - then again, you'd expect that if you were buying tens of thousands of cars per year.
Tom B
4,710
16
Northampton
110k change interval? You're having a laugh, right?
In the previous owners hands, my Ibiza's cambelt snapped at 69k, and I know of a few other ABF ones snapping early.
My rule of thumb is 40k. I'd rather pay for a cambelt change than lose my car for god knows how long and pay god knows how much for a top end rebuild.
SpareMan
354
jcs356 said:
Yep.
Rubbish! You think that VWG wouldn't care if large numbers of their petrol models cambelts were breaking left right and centre before they should be and ruining engines? What sort of publicity would that create (remember the coil packs / watchdog)? Using your theory why dont they make all petrol cars cambelt changes be at 70K after most leases have run out, that way they keep the lease companies happy and cut down the possibilityof bad publicity?
If cars are serviced correctly and the belts inspected there should be no problems. The question is can you trust whoever services your car to do a proper job? (and thats in or out the dealer networks).
Fleets hate variable servicing (I know I worked at one not that long ago) because brake wear isn't checked regulalry. Therefore brakes go metal to metal (OK they pass that cost onto the drivers but its hassle) or get changed earlier than required which costs them. Most fleets get dealers to reset the service back to fixed if possible. In fact the cost of a variable service was more than a lube and 20K put together so it doesn't save money for high mileage vehicles.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Sparesman - I know you're clearly in the trade, but ABF timing belts snap early.
This trend started about 5yrs back where they started going before 60k, on more than a handful of cars.
It's a cheap simple job, that's easy to do. 2hrs tops.
Servicing past a certain age becomes more of a rolling event for me, so oil change one week, plugs a week later. I haven't the concentration to sit there for a day and do it all.
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
Ooh, this is getting juicy;)
Yes, I am saying they don't care. With respect, the outcry on the coil packs was slightly different as they were failing either within or just outside the 3 year period - hence the expectation that VAG should do something and it was such a widespread problem - even then, it was down to local garage goodwill in many cases whether you got it FOC or had to pay (experienced that myself on my S3 - completely different treatment from 2 local garages).
VAG are basically saying, then, that if you are Mr Average, doing 12,000 miles a year, have your car serviced at a VAG dealer as per the recommendations for 10 years, and the belt goes at 129,000 miles just before it was due to be replaced, then they will cover the cost of a top end rebuild?
But how many cars are treated in this way to full dealer service that far into their lives? How many cars even reach that sort of mileage being dilligently treated and everything stamped up. What about that time when the garage was really busy and you went 500 miles over the service recommendation. Surely VAG could argue that you didn't service the car 'as per the manufacturers recommendations?' and hence absolve themselves of any obligations they may have had?
Even if you had a personal car that you did big mileage in - my dad put 130,000 on an early Mk2 Golf GTi 16v in 3 years, you would still come a cropper under the other part of their warranty - i.e. the 60,000 mile limit.
Another example, a friend with an Alfa 156. Bought from new, only did about 8000 miles per year, serviced exactly to Alfa's spec. Cambelt schedule was 60k (from memory), it went in the mid 40's with the car 5 and a bit years old. He'd had it serviced and inspected just as he should - were Alfa interested? Nope. Would VAG be any different? Nope.
That is their ultimate 'get out of jail free' card in that they have a 3 year/60,000 warranty. i.e. anything happens outside those terms and conditions and there is no obligation for them to do anything - even if you have followed the maintenance schedule to the letter. Funny how that warranty also fits in with fleet terms.
Ultimately, you are quite within your rights to follow what VAG say to the letter, but if you fancy a fight with a faceless corporate giant who is more interested in making money for its shareholders than anything else (any PLC who says anything else is lying) then good luck to you. Did the coilpack debacle cause a long term problem for VAG? I don't think so.
As an aside, here is what Honest John from the Daily Telegraph has to say about both variable servicing and timing belts:
http://www.honestjohn.co.uk/faq/faq.htm?id=13
Here is the salient bit on timing belts:
...If the engine has a timing belt, change that every 3 to 4 years or every 40,000 miles, whichever comes first, unless the engine has no history of premature timing belt failures (Ford Zetec E and Zetec S engine timing belts generally exceed their design life of 80,000 miles, so can be changed at 6 years or 80,000 miles, whichever comes first.) Change the timing belt tensioner and any weeping camshaft or jackshaft oil seals at 80,000 miles (every second timing belt change for non-Ford Zetecs). VAG belts generally good for 60,000 miles. Early VAG 1.8 20v engines had water pumps with plastic impeller which can fail, throwing off the belt, so belt and water pump should be changed by 60,000 miles....
I think what we have confirmed in the earlier posts is that unfortunately some VAG engines do have a history of snapping belts prematurely. VAG don't publicly admit that, but I think enough people in the trade know about it by now.
Yes, I have contacts in the trade. My brother is the operations and risk director of the UK's largest car fleet, and has worked at a senior level for various other UK fleet companies over the past 10 years or so. OK, he isn't a mechanic so doesn't see what happens on the ground. But he, and his department, are responsible for ultimately deciding how much it will charge it's customers for leasing it's cars. Get that wrong and they can loose a fortune. Included in the complex algorithm used to calculate this are various things around the UK's economic performance, interest rates, inflation etc. together with base vehicle cost, anticipated servicing costs and other consumables such as brake pads, tyres etc. etc.
So if you can shave a few £100 of the servicing costs thanks to variable servicing or not having to change the timing belt, then the number the algorithm pops out with at the end will be lower, making that car cheaper for the end customer to lease, and hence meaning that manufacturer will sell more cars to the leasing company as the car is more attractive to the customer.
Some are bound to fail within the 3 year/ 60,000 mile period - in which case, VAG just have to pay up as they are covered under the warranty.
Reference the brakes. Most cars these days have brake indicator warning lights. Ultimately if a warning comes on and the driver chooses to ignore it until you get metal on metal wear, then that isn't going to be covered under the standard Ts and Cs of a lease. My brother's experience is that fleet cars are generally well maintained as people have paid for the service. If you've paid for full maintenance, why not use it? Why run round with the brake pad warning light on when you know you can get the whole thing sorted for free. If you've got your numbers right in your pricing algorithm, you'll account for the fact that some brake pads will be replaced early.l
In summary - who do you believe - the manufacturer who'll tell you anything to get you to buy their product; or the people on the ground who've got experience of how things actually work. That's the beauty of these forums - you can use the collective experience of many people to answer the question.
Finally, apologies if any of this has caused any offence to anyone. Just having a bit of a rant. Thanks for reading.
SpareMan
354
This is good, as you say it is what forums are for
The over-riding factor in setting lease rates is residual value, that is what your brother would be most interested in, lease companies got stung 4 or 5 years ago since 2nd hand car prices plummeted and were not worth the RV when it came time to sell them on. My expereince of fleet cars is that a lot of them are thrashed because the driver knows it is not his to pay for or worry about selling. These sort of drivers are late for their service, ignore warning lights, invalidate warranties, admittedly a minority but a large minority if that makes sense. You could argue that its these cambelts that are likely to break. Similarly with private customers who don't look after their car. One of my arguments in an earlier post was that if the car is serviced correctly and you can trust it to be looked after by you mechanic then there shouldn't be many problems. But as you say how many cars are treated this way? The world is not ideal, each person has to make their own decision, all I am doing is putting the other side of the argument so people can. So the whole I agree with you, a good post, to some extent I am playing devils advocate - its a weakness of mine.
Let me tell you my experience. I have been in the trade for more years now than I care to remember covering a lot of different aspects. I started working in a maintenance department at a lease company, specifically in customer services, moved to another similar dept in VWG itself, then moved to work within another brand in VWG and now find myself out in the dealer network. I have only once come across a timing belt snapping early, that was not a VW car and it had not been serviced regularly. So my experience is that it is the exception rather than the rule. Admittedly a costly problem but we take risks crossing the road.
Using the logic that its best to be safe than sorry then why dont we all get our tyres changed when they are half worn. They are safer in the wet with more tread and become less and less safe as tread wears. So we take a risk the more we drive and that could be life threatening. But there is a limit when someone somewhere has decided they are unsafe (1.6mm). Thats when they must be changed. Again, like cambelts it is personal choice. I know a few people that will not let their tyres go below 4mm, butof course we all know that there are many cars out there with illegal tyres.
