Hey all its nearly New Year and as im skint at this time of the year my 2nd service will need to hold off until the end of january is there any bits i csan check and make sure im alright until then? ie antifreeze etc, and filters in sure there cheap enough, any thoughts?
Well the SEAT service schedule on the Ibiza (not sure about other models) has a 1,2&3 level of service.
The second service you need isn't anything too major, if you keep everything topped up (fluids, tyres, etc) you won't go too far wrong! This will be ok as long as you ain't doing massive mileage, then you'll need something doing soon!
You could also consider using an independant agent (I use mackenziesvwaudi.co.uk) who have done my last two services to a higher standard than the local dealer and for almost half the cost!!
I use JKM Performance in Portsmouth as they are a VAG specialist. Only used a dealer when it was under warranty. Here is a link to their service page on their website and it tells you what they do and what it all costs.... http://www.jkm.org.uk/performance/service.htm
