Fisher2007
Hi
Any chance someone could confirm the situation with servicing on a VZ1 March 2023 registered vehicle please, as I'm getting mixed information from the dealer (where I'm buying the vehicle) vs Cupra UK.
Dealer is telling me first major service not due until the vehicle is 4 years old. Cupra UK saying service intervals are minor then major, alternating every 1 year or 10k miles basis (whichever is sooner), so therefore first major at 2 years old or 20k miles.
Dealer tells me the vehicle had a minor service early 2024 and they have just done another minor service last week, which fits in with their own servicing profile but not what Cupra UK have told me.....
Also, anyone know the cost of minor and major services please? Cupra UK couldn't tell me for some reason!
Hi
Any chance someone could confirm the situation with servicing on a VZ2 March 2023 registered vehicle please, as I'm getting mixed information from the dealer (where I'm buying the vehicle) vs Cupra UK.
My dealer has always followed the schedule that CUPRA above have quoted you, and I thought all dealers did this. Only difference was if the car was on the longlife oil set up (for owners who did lots of motorway miles) rather than the annual (10,000 miles) regime.
I can speak for German one. Once a year oil change, and every two years heavy maintenance. You can see the same on the infotainment panel too.
Reactions: Cupra_33
I go by what the car tells me. Says in the manual:
Service interval display
At CUPRA, the dates of the services are indicated by the service interval display on the instrument cluster ››› page 28 or in the Vehicle settings menu of the infotainment system
››› page 35.
The service interval display gives information for service dates that involve an engine oil change or an inspection. When the time for the corresponding service comes, additional work required, such as the change of brake fluid and the spark plugs, can be carried out.
Service due
When it is time for a service or an inspection, an audio warning will sound when the ignition is switched on, and a spanner symbol may appear for a few seconds on the instrument cluster display , along with one of the following
messages.
● Service now!
● Please have your vehicle inspected
● Oil change service due!
● Oil change service and inspection
due!
Oil change every year
Oil change service and inspection every two years.
That is the schedule for my VZ e-Hybrid. Maybe it is different for normal benzin or diesel cars.
Reactions: Cupra_33
From cupra UK
Petrol and e-HYBRID models
Servicing is recommended every year or 10,000 miles, whichever comes first. The vehicle may also indicate when an inspection is due.
There are three types of scheduled service:
- Oil change (first year only)
- Oil change and inspection
- Oil change and inspection with supplementary scope
After the first year, these will alternate between the oil change with inspection and the expanded inspection service.
That says to me that the 'major' service is in year 3. So
Year 1 oil only
Year 2 oil and inspection
Year 3 oil and inspection plus supplement
Year 4 oil and inspection
Year 5 oil and inspection plus supplement
They don't make this easy at all.
Hi,
This is the VAG group recommendation.
The minor service (every 10000 miles or 1 year if you use non LL oil) corresponds to an engine oil + oil filter replacement, then some visual checks.
The major service (every 20000 miles or 2 years only if you use LL oil) corresponds to a minor service + cabin filter change + front wipers replacement.
If your Formentor is DSG equiped, DSG oil change is every 40000 miles
Then depending if your mileage is 60000 or 80000, there are other operations according to your engine (petrol or diesel): air filter + diesel filter / spark plugs (every 60000)…
Don't forget brake fluid replacement at 3 years old and then every 2 years.
It’s up to you to follow recommandation or not.
It also depends on whether you are allergic to pollen or something like that.
At least, if you have a small compressor at home, you could blow your cabin filter to remove dust and pollen.
If your warranty is not over, then you have no choice but to do what your dealer says.
If your warranty is over, then it’s not something that will compromise the reliabilty of your car. But I don’t think not replacing it will enable big savings…
I am really confused my hybrid is coming up to 4 years old. my car is on a lease and is being handed back 10th July the service is not due until 17th july. but the car is saying I need a service in 500 miles I got the old service receipt out. if service intervals are every 10000 miles mine will be due at 9000 miles. I don't want to service it and hand it back? Anyone have any ideas ?
The service interval mileage is in KM. When it's expressed in the UK in miles, they're usually a bit off the mark.
Your case for example - the service interval mileage in the vehicle computer will be programmed to trigger around 15,000km, which is 9320miles (ish), so you're really not that far off.
Reactions: Ian986
Thank you for the explanation (y)
I left my car at the Cupra specialist service yesterday, and today I am going to pay 1043 Euro for 4 year old car :(
My VZN @ 2 years old and 11,200 miles is due an intermediate service, last year at my CUPRA dealer the service was £235 now this year they are quoting £435 for the same service as the pollen filter needs replacing, when I questioned the increase they reckon its because they were using SEAT labour charges and not CUPRA service charges!
1 CUPRA dealer £263.
2 other CUPRA dealers £290 inc the pollen filter!
1 CUPRA dealer the same group as my dealer £329!
What have you been charged for the 2 litre VZ long life oil, filter & pollen filter change?
Looks like I have been lucky as they have quoted me £220 for the service as i said I was giving the car back and £50 extra for MOT.
The Seat/Cupra dealer has told me that they have been told by Cupra that they must charge £149.50 per hour labour for the service!
Well, my extended warranty will be over next year, so I have no intention to bring this car to a "specialist Cupra service". I am still searching for a reliable and cheap service point in Munich and surrounding areas. Any tips? I am also thinking about doing oil change in nearest fuel station. Should cost 1/4 of service price.
If I manage to gather money, I will get X3 or GLC but with my current salary it doesn't seem to be possible :(
My VZN less than 2 years old, today I booked car for my 3rd service.
Very strange thing they said aircon service which I rejected. As there was price associated.
So went for only oil / oil filter 263£ and Haldex 125£
Now this is new air-conditioning service, has anyone been told this is now part of service if I don't get it done it will spill into next service?
This is pure money making tactics as far as I think.
Thanks.
