Feb 22, 2009
3,459
South Wales
So here is the new addition to the vag family
put the MK4 Golf TDI in for a Sharan TDI
This is what I am going to refer to as the ShAlhambra allthough the kids have callled it the Shellyran or Shellyvan sometimes
:D More Power
:D 6 Speed
:D 7 Seats
:D loads of room
Mods so far:
Kenwood Bluetooth Headunit
Baby inside vinyl
Tinted glass
LED side lights
towbar
philips vision plus h7 lamps
To do: not in order
hids
Remap
Personnalised plate (?)
Colour coded mirrors
rubber mats
debadge
wheels
decat
mufflerectomy
Cruise control
side bars
mud flaps
bumper guard
Shopping List
Genuine part numbers from VAGCAT
7M3857919B part 14
7M4867180 part 23
7M3959855 part 4
7M0868479C part 4
Does the knock happen when theres a change of inertia? (ie, press the brakes, clunk, press the accelerater, clunk, press the brakes, clunk... You get the idea :) ).
If so im 99.9% sure it'll be a front top mount.
check the anti roll bar links and track rod ends as they are both common and similar sounding faults
if you are under there give the bottom ball joints a once over too
it is proper for a family, indeed
I know makes sure my leon can become the toy
some pics from this weekend (Leon is being spoilt next weekend with a full detail)
fitted the towbar friday evening - straight forward bumper not as secure on this now as you have to remove the original crash bar
Saturday I removed the rear lights as the near side lamp unit was allowing water in see discolouration in pic above
the pinky purple shows where the boot panel is clipped on and the red shows the 2 screws which hold the panel on - MUCH easier to remove than the Leon boot panel
Next on the shopping list :D
just got in again working on the shells sharran :( had a bulb go so time to fit the new ones which Ihad in the shed for the Leon
fitted philips vision plus h7 lamps - really look great with the LED side lights
Top of the lamp unit was spilt allowing the lamp to partially fill with water.
When the boot was lifted this water poored through the fog bulb (lower) apature into the space between the boot and the inner pannel.
hope that helps
Top of the lmp unit was spilt allowing the lamp to partially fill with water.
When the boot was lifted this water poored through the fog bulb apature into the sace beween the boot and the inner pannel.
hope that helps
Cheers, I'll have a look. I get some water coming from the nearside inside lamp cover when I raise the tailgate.
