Show off your mk2 ibiza :)
panosib
i asked again but now i know exactly the person that can give me an answer.
that person is yousimonthekane :rolleyes:
what is the lowest i can go?i have 17in wheels and kw variant 2 coilovers.now my car is lowered about 70mm.the only broblem i see by my self is that the steering shaft(i dont know if it is called like that.i mean the bar over the drive shafts which is to give move to the wheels left and right from the steering wheel) is very close to the chasis.
do you have the same problem?any solutions?i am waiting for yor answer
simonthekane
Ibiza Cupra Sport
To be honest im not sure 100% what bit you mean :(
Never had any problems with the front on my old 20vt and that was lowered around 80mm + , and no problems with this one either.
If your on coilovers my advice would be to adjust it lower bit by bit and see if it gets any closer.
cuprafish
simonthekane said:
Yeah its still standard mate, and it does knock on the rear beam on big bumps so is you have an after market one you will have more problems unless its been adjusted higher up.
just looking into exhausts at the moment, powerflow have told me they will take the pipe under the rear axle as my car is lowered 45mm has anyone done this or is it recomended??
panosib
i will try to upload some pics to show you what i mean.
i have my camber at 2 degrees opposite(if i go about 1.5 you believe my problem will be solved?)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i better wash mine / polish it and get the bodywork sorted out then
too much bling in ere [B)] :p
pics are iffy - only a camera phone
