Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
im getting a slight screechin noise from outside the car when im driving slow, at 30 mph it goes, sounds like brake pads worn? but i dont have a light on the dash! plus they arent that old. Its more noticable at low speeds but doesnt do it all the time. Any ideas?
if it's a high pitched squeak the try and tighten the wheel hub nut,,, that's the big one in the center of the wheel, not the 4 wheel nuts,,, you don't even have to take the wheel off, just jack up the car and tighten the big nut with the compressor,,, this is due holes and bumps and stiff suspensions,,, on mine it lasts very short, gotta tighten them very often,,,
BTW, pay attention, cos if it looses too much, the wheel could touch the disk and ruin it or it could ruin the bearings stressing them with misplaced weight,,,
if you have a big enough wrench you can try and do it yourself [provided you are strong armed] but I'd suggest going to the garage, even a tyre shop can do,,, it's a no brainer, a 1 minute job, you pay them a coffee and that's it,,,
