When I drive my Cupra tdi, occasionally when I accellerate the revs go up as if power is being bled away somewhere, instead of acellerating normally, there will be a delay and the revs will rise and no froward momentum will be felt! Even if i leave my foot down the revs will fall back and the car will continue to acellerate normally, not like a clutch slipping which would continue to slip if foot was lft to the boards!
The car only does it intermittantly, im sure just to piss me off, so that when I take it to seat they can tell me there's sod all wrong with it!! I hope ther is sum1 on ere who has had a similar problem, and its not just me going mad!!! PLEASE SOMEONE HELP ME!!!!!!!!
Seat dont no wot the problem is, do any of U?????
Cheers, James.
Cheers, James.
Thats clutch slip mate. If your car is standard and still under warranty you can try to get Seat to change it for you but you will have to be very persistent as they will not replace it easily. Personally i would just get an up rated clutch fitted. Helix and Sashs are the two main clutch manufactures that people use and are both very good.
