Sod the air con!!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Knigh wrote
Interesting!!! I understand the point re: drag etc - but how on earth do you come to the answer that at 20 mph it is better to have the cc on and windows closed?
By grossly over-simplifying, of course :D
I did some searching and found some university projects that had adressed this issue, and one manufacturers research project which quoted numbers. From what I can tell, at about 25 C outside temp, aiming for 22 C cabin temp, their conclusion was that the drag rise from open windows crossed over the power consumed by the aircon compressor at about 20-30 mph. It does depend on the engine, as the aircon compressor power consumption (when it is on :) ) is dependent on engine rpm, not speed, so keeping in a high gear reduces the losses from aircon. The aircon power consumption is relatively flat and at motorway speeds is considerably less than the open-window drag. Ofcourse if you have aircon fitted then you are already paying a penalty for dragging around all that extra weight, so it makes sense to use it where it pays. Around town it is unlikely to make a lot of difference which you use.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
WAIIII VWIIIING
Leon the Diesel
91
Billericay, Essex
ponydust said:
Morning All
Saves petrol aswell not using climate!!
Yes and no.
Yes- no a/c saves you fuel. Open windows = aerodynamic drag = more fuel.
Probably no discernable difference in practice.
Also unless you use the a/c at least once every 14 days I understand the compressor suffers. ie expensive.
Spanky
Banana Virgin..
Feb 5, 2005
584
Preston, Lancashire
In both my and the wifes car (2.0 XSi 307) the mpg for the whole week (over 300 miles) is about 5-6mpg less with the a/c on, than with the a/c off and windows down.
