Hello mate!
Real clean butterfly valve! Its weird how they put the airbox inside the engine cover.
That blue circled bit is what I previously mentioned, its the heat sheild for the exhaust manifold, manufacturers plumb hot air off them to contol fuel emissions and so on. You don't need it and it actually reduces your performance as the air your intake pulls in is less dense with oxygen. Whether you will notice a difference or not though.
As for the other pipe it is coming from the rocker cover so looks like it is a breather, I will find out for sure for you (Don't know the 1.4 layout). If it is you can just cut the pipe and bung a small filter on the end. :)
Sent from my GT-I9505 using Tapatalk
Aye it's low milage for a 56 plate - bought in on 13000.
So for the blue circled bit, I can take the cover off fully and just leave that? I was speaking to a friend who's well into modding cars earlier and he said it was an oil breather. If I was to take the cover off it's cool to leave that with no extra parts or do I need to buy something to put over it?
The other pipe(tube connecting the cover to the engine I assume you mean) - when you say cut it and bung a filter what do you mean by filter? As in clamp it shut with something or do I need some kind of filter on it?
Cheers for your help dude. You've been a lifesaver with this :D If you could get back to me when you know about the breather for sure I'm going to buy an induction kit tomorrow and fit it :)
Nice man :D looks good. Seems like you got a good buy. I am assuming your engine code is BBZ, 100bhp engine. I managed to find some assembly drawings of that engine, so I will try to help as much as I can from what I can see :D
Sorry man but your friend is wrong, it is an exhaust heat shield, as I said earlier it is plumbed into your car for fuel emissions, especially on cold starts etc, warms your cat up quicker. It is definitely not needed. You can even just remove the plate completely, it will make your engine bay look a lot nicer, will get a bit warmer but its nothing to worry about :)
As seen above it sits over the exhaust manifold, trapping warm air and allowing your intake to suck it all in.
That other pipe thing, its connected to a one-way valve on your cam cover. This is designed so that the cam cover can breathe but can only breathe and not draw anything in. Basically as your intake pulls vacuum it opens the valve allowing the case to breathe freely. The action you should take with this, is take the pipe off, remove the one way valve and connect a small breather filter to the cam cover outlet with a small bit of pipe, or just onto the outlet it's self. It can be seen below.
6. Pipe that is connected to cam cover outlet
8. One way valve (remove that)
9. Pipe that connects the one way valve to the airbox/cover
At the end of the day as long as the cam cover can breathe, allowing all that positive pressure to escape, your engine will run like normal. Bung a filter on the outlet, and the thumes will breathe into the atmosphere. No problem.
No idea where your crankcase breather is located, unless they are linked in someway...not sure on that one. :blink:
But putting a filter on that outlet will be completely acceptable.
http://www.ebay.co.uk/itm/Mini-Air-..._Hearing_Cooling_Air&var=&hash=item4ababf9f75
The above link is an example of a breather filter, you can buy them all over ebay and they are relatively cheap. Just check the diameter of the outlet so you can buy the correct size.
Also the induction kit you want to buy, does it come with intake piping to connect your filter too? Unless of course you are planning to put the filter straight onto the throttle body :)
I found this on K&N, they mount the filter directly on to the throttle body but the great design with this filter is that it has all the pipe work for your breather, so you can connect it up to your one way valve and you are ready to go, no additional filters needed.
http://www.knfilters.co.uk/search/product.aspx?Prod=57-0544
The instructions below show you how it all goes on :)
http://www.knfilters.co.uk/instructions/A2054-581_inst.pdf
Kits like that are great as it is just a case of everything is already there and all you have to do is put it on :) There is a rumour that K&N air filter oil messes with MAF sensors, but I am sure you would be fine to use one. I used a 57i in the past and had no problems :)
Hope that helps mate, and I haven't confused things even more so!
