ive got a new car and i love it but due to some muppet its making a funny noise when i first pull off from time to time,it only does it when i first start up with the clutch,grating sound.its not all the time tho..my worrys are that its the box..can anyone help.ps im new on here
rite its done it when i frist pull off lifting the clutch at first i thought clutch slip but that would be all the time then i think maybe becoz it does it up hill first thing maybe box oil ... but my fear is its the gear box synco mesh ???!! HOPE NOT... i will try and record the sound tomorrow..ow it sounds like the middle of the car at the front.sounds like a spoon being rubbed alone a bit of ridged bit of card board onlyy for 2 ton 10 secs i know its a hard one
I have experienced the same problem.
I cant believe there arent more people who have had this problem.
If i get to the bottom of it il update you, you need to do the same.
Have you checked the mk2 ibiza forum for an answer? same mechanicals.................
yeah will keep it u all posted i think its gear box oil thinning out and or low as its alway up hill when it does it..!!im going to try some molyslip in there too as ive used that before and i really rated it..!!!!il keep people in the loop ..many thanks for all the help everyone has given!
Got to the bottom of it, mine is apparently the EDL engaging so nowt to worry about. May be worth visiting the Ibiza forum in future as theres more traffic in there.
I was sold my Cordoba from a dealer nearly 9 years ago with "traction control" but it seems its not "proper" TCS! Maybe as time goes on it has changed. Mine used to kick in randomly for no aparent reason. Then had an ABS sensor replaced for an MOT and now it behaves itself.
Glad you got to the bottom of it!
Ive used molyslip and its has made some differets but i will look in to the abs senor!!! thanks very much ps i would highly recommend mollyslip to all car lovers
