When I worked for an avionics systems contractor, I "saved" an unopened tube of that Dow Corning stuff from being binned as it had gone beyond its internal QA "time", it has lasted a very long time, the plan is to only apply a small "ring" of it round the lower surface of the HT connector extension, making sure that the "ring" is small enough diameter so that it applies itself to the insulator of the new plugs when you fit the coils back on. These plugs have a solid thick copper sealing/bearing washer BTW.
