craig_b
Hi Guys
Ive had my biza for 2 years now, and surprise surprise its out or manufactures warranty now, so things go wrong!
just had to get the wire works the reverse light as it was all brittle and snapped in several places.
Also I have an annoying squeak that comes from the front left of the car. Ive had my local garage look at it and they can not find anything wrong with it. Suspension is in fully working order. I have attacked my car with WD40 the door hinges, suspension, basically anything that moves. The squeak is still there. It normally only squeaks when going over a bump, or when breaking and turning at the same time.
Does anyone have any ideas?
Mine only does it when it's been raining, water gets into the spring/shock or something and when you go over a bump it squeaks!
yes the squeak from the suspension is a 'feature' of the car, always happens when wet or damp, or icy.
Shocking if you pardon the pun.
check your suspension top mount on the strut the rubber can cause a squeek when there is movement on suspension undo the 3- 13mm's and lube up rubber
