18psi is more then 1bar, sounds a bit hight to me.
But I'm new to VAG's so I might be wrong. Just after the petrol numbers realy though
A CC stage 2 K04 from a LCR runs 1.25-1.45 (18psi) at peak so doubt you are running 21-22 on a K03S??
Sorry evo, don't mean to be contradictive, was told petrol turbos run lower boost even after a remap!
thats what the gauge shows peak 21ish and holds at 15-16ish. thats running revo stage 2. from memory gaz jones car was running the same boost with the same setup as me
My cupra at the time was 0.6bar hold (8.4psi) and 0.8 (11.2psi) peak for my standard setup now on a stage 1 it 1bar (14psi) hold to red line with 1.2 (16.8psi) peak. Looking forward to p-torques stage 2 but that requires 2 days to map. Can't get the time off work for that [:@]
have you changed anything on your car since the last remap??
