Hi guys, for some reason my car has developed an odd boost problem, it 'appears' to be since i removed my N249 and N112 valves compleatly, 4th or 5th gear (not sure about lower gears) i'll put my foot down and get a peak of about 19-20psi on the boost gauge, then it'll instantly drop to about 10psi, but then creep up to 'normal' figures', altho sometimes it will just stay at 10psi and do nothing else (this is mainly in 5th).
i've checked for boost leaks, tweaked the actuator etc, with no success.
I've also done some logs of group 115 & 118, however they don't seem to show the same as my boost gauge, also no fault codes were thrown.
This is 4th gear, 2.5k to 6k rpm (i've cut out the other crap untill the moment it requested more boost)
BTW I'm JabbaSport Stage 1 mapped, also have an ECS N75 Race Valve.
Not sure if it's peaking too high (at one point i calculated it to be nearly 22psi
Could it be going into temporary 'soft' limp mode for a short time? and maybe the times between the log data is too long to see the drop?
Any help would be appriciated
EZT
Code:
Wednesday 18 March 2009 15:12:33
6K0 906 032 AA 1.8L 20VT EU3 01 0002
Group A: '115 Group B: '118 Group C:
RPM Load Absolute Pres. Absolute Pres. RPM Temperature Load Absolute Pres.
TIME TIME TIME
Marker STAMP /min % mbar mbar STAMP /min °C % mbar STAMP
307.52 2560 67.7 1010 1380 307.12 2520 24 0 1400
308.32 2760 118.8 1870 1490 307.92 2640 24 1.2 1360
309.12 3080 168.4 2000 2080 308.72 2920 24 87.1 1780
309.92 3480 171.4 1920 2500 309.52 3280 24 76.5 2400
310.72 3800 138.3 1890 2080 310.32 3680 24 55.7 2330
311.52 4120 144.4 1890 1970 311.12 3960 24 50.6 2030
312.32 4360 146.6 1860 1970 311.92 4240 25 50.2 1950
313.12 4640 143.6 1820 1930 312.72 4520 26 49.8 1970
313.92 4920 139.1 1750 1850 313.52 4800 27 45.9 1890
314.72 5160 135.3 1710 1780 314.32 5040 27 43.1 1820
315.52 5360 129.3 1700 1720 315.12 5240 28 37.3 1740
316.32 5560 133.1 1680 1720 315.92 5480 29 40.4 1670
317.12 5800 130.8 1660 1680 316.72 5680 30 39.6 1670
317.92 6000 124.8 1570 1590 317.52 5880 30 34.1 1660
) Could it be going into temporary 'soft' limp mode for a short time? and maybe the times between the log data is too long to see the drop?
EZT
