Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
My car has been boosting regularly at 10 psi but i have noticed that if i give it some stick its boosting as usual after when i drop down to regular speeds and rev's it wont go over 5 psi? then when i turn the car off it returns to normal until i boot it again, i have Vagcom'd it but nothing showing. the car appears normal except the boost, it is only recently i have noticed this, or it has started tod o it, the cars not heavily modded just 007p Dv (on the wrong way round), neuspeed air filter and LCR twin intercooler conversion all of which have been on for a long time. the only fault that is showing is the usual pressure drop between manifold and Dv ( check DV ), i know a lot of people get this fault i have checked all the pipes and the DV but found nothing.
I Would appreciate any ideas as to what MIGHT be causing this.:D
Have you tried turning you DV back to the correct position to see if thay cures it?
As above, split hose?
I've noticed my n295 valve hoses look dodgy but there soon to go anyway
I was planning to do that as it was the last thing i did, i have allredy got rid of my N295 and the other one which i forget the number of now. what i dont under stand with the pressure drop is why it drops to 5 psi and not 0 if there is apressure drop why is it the same every time?
